20 Most Recent
Jensen XA2125 Car Audio Amplifier Questions & Answers
Jensen XA 2100 Amp. Need
the black wire is ground, white is + and white/black is - that's for the left side speakers and the gray is + and gray/black is - that's for the right side speakers and that hooks up to the speaker wires coming from radio to high level input plug if you need a diagram this is the website http://a248.e.akamai.net/pix.crutchfield.com/manuals/110/110xa2100.pdf and look on page 5 it will show you. please vote and leave high marks. Thank you and I hope i answered your question
Jensen vm0312 is on, but tray will not flip up
It sounds like there may be an issue with the mechanical components of the DVD player, specifically with the tray. Here are some troubleshooting steps you can try:
- Check to see if the emergency eject feature is working. There should be a small hole on the front of the DVD player, and you can use a paperclip or a similarly sized object to push the button inside. This should manually eject the tray.
- Make sure that the DVD player is receiving power. Double-check all of the connections and fuses.
- Reset the DVD player by disconnecting the power for a few minutes, then reconnecting it and trying again.
- If none of the above steps work, it may be necessary to take the DVD player apart and check the mechanical components for damage or wear. However, this is not recommended unless you have experience with electronics repair.
If none of these steps resolve the issue, you may need to seek the assistance of a professional electronics repair technician.
How to bypass jensen
I just purchased the VX7020 and went to Settings-Language-typed in 5,4,3,2,1,0 but the menu never came up. Any ideas?
