20 Most Recent
Jensen SAB-55 Radio Questions & Answers
How to program stations
1.Tune to the desired station
2.Press Mem/Time button (MEMO will blink in lcd)
3.Select desired channel number
4.Press Mem/Time button again
hope that helps....just repeat to set other stations
Changing batteries
First don't let the batteries go completely dead. Second take out one battery and put in a fresh one then remove the other weak battery and replace it. If you do it this way and work quickly you will be able to retain all of your presets and time function.
How to set Stations
u set up the channel u want with "tun.up"\"tun.dn"
press the "mem.ch" for five sec untill it flickers or beeps
now u know its in the memory
do so 4 any station u want
How to set time on jensen jcr-425
To set the time on a Jensen JCR-425 clock radio:
- Press and hold the "Time Set" button until the display flashes.
- Press the "Hour" and "Minute" buttons to adjust the time.
- Press "Time Set" again to confirm.
Jensen Compact Disc Music system JMC-500W. Open/Close button not opening the lid
Please hold down the open/close button instead of just pressing it. Then you can press the lid while this is happening. I think you might already suspect this, but it sounds like the hook that connects to a portion of the lid isn't unhooken during the button press. Friction might be a cause or the hook-movement might not be functioning as smoothly due to other factors.
If the issue continues, we might have to consult Jensen on a potential repair/replacement of the item as well.
