20 Most Recent
Jensen MCD-9424RC CD Player Questions & Answers
Wire conection problem-no manual
Black is obviously ground. red is for switched power (only has power when vehicle is on) single yellow or orange is constant power Dual grey and dual white (solid grey/grey with black) and dual etc. are for speakers. the blue is for accessory power for amps and eq's. on the speaker wires the one with markings is for + and the soild is for -.
6/8/2009 11:23:53 PM •
Jensen...
Answered
on Jun 08, 2009
Jensen vm0312 is on, but tray will not flip up
It sounds like there may be an issue with the mechanical components of the DVD player, specifically with the tray. Here are some troubleshooting steps you can try:
- Check to see if the emergency eject feature is working. There should be a small hole on the front of the DVD player, and you can use a paperclip or a similarly sized object to push the button inside. This should manually eject the tray.
- Make sure that the DVD player is receiving power. Double-check all of the connections and fuses.
- Reset the DVD player by disconnecting the power for a few minutes, then reconnecting it and trying again.
- If none of the above steps work, it may be necessary to take the DVD player apart and check the mechanical components for damage or wear. However, this is not recommended unless you have experience with electronics repair.
If none of these steps resolve the issue, you may need to seek the assistance of a professional electronics repair technician.
How to bypass jensen
I just purchased the VX7020 and went to Settings-Language-typed in 5,4,3,2,1,0 but the menu never came up. Any ideas?
