20 Most Recent
Jensen XCD9120 CD Player Questions & Answers
I lost my harness,i need a picture of one so i can
red wire is the positive wire black is the ground, yellow is memory connect it to a constant power source such as battery this will sustain your clock time ,radio stations set etc. also green wires are speaker positive and negative one has black stripe does not matter accept when you connect them make sure all speaker wires are connect the same meaniing all black striped wires are your negative connection. your white wires are the same way to be sure of speaker wires each collor will have only 2 wires. If you have RCA connections red for right channel and white for left. Hope this helps.
Jensen vm0312 is on, but tray will not flip up
It sounds like there may be an issue with the mechanical components of the DVD player, specifically with the tray. Here are some troubleshooting steps you can try:
- Check to see if the emergency eject feature is working. There should be a small hole on the front of the DVD player, and you can use a paperclip or a similarly sized object to push the button inside. This should manually eject the tray.
- Make sure that the DVD player is receiving power. Double-check all of the connections and fuses.
- Reset the DVD player by disconnecting the power for a few minutes, then reconnecting it and trying again.
- If none of the above steps work, it may be necessary to take the DVD player apart and check the mechanical components for damage or wear. However, this is not recommended unless you have experience with electronics repair.
If none of these steps resolve the issue, you may need to seek the assistance of a professional electronics repair technician.
How to bypass jensen
I just purchased the VX7020 and went to Settings-Language-typed in 5,4,3,2,1,0 but the menu never came up. Any ideas?
