20 Most Recent
Jensen MP5620 CD Player Questions & Answers
Jensen MP5260 Wont play any cds.
she's gone, i have same problems.. buy a cig lighter mp3 player with remote for less than $10 and just tune ur radio into the brodcast station
Jensen MP5620
I dont know if this will work for the mp, but for my jensen 2010x ,while it is on, you press on the (disp) button for 5 seconds untill the clock starts flashing, then on the FF to set minutes and the rewind button to set hours. I literally spent 2 hours playing with it till i figured this out!!!
Display ok, no audio
poor connection somewhere or heat problem causing cold solder joint
as such to lose conductivity. Time to look for it using cold spray.
Good luck
Jensen vm0312 is on, but tray will not flip up
It sounds like there may be an issue with the mechanical components of the DVD player, specifically with the tray. Here are some troubleshooting steps you can try:
- Check to see if the emergency eject feature is working. There should be a small hole on the front of the DVD player, and you can use a paperclip or a similarly sized object to push the button inside. This should manually eject the tray.
- Make sure that the DVD player is receiving power. Double-check all of the connections and fuses.
- Reset the DVD player by disconnecting the power for a few minutes, then reconnecting it and trying again.
- If none of the above steps work, it may be necessary to take the DVD player apart and check the mechanical components for damage or wear. However, this is not recommended unless you have experience with electronics repair.
If none of these steps resolve the issue, you may need to seek the assistance of a professional electronics repair technician.
