20 Most Recent
Jensen MCD5110 CD Player Questions & Answers
Mcd5110 marine radio cd player
Gary,
Sounds like channel 1 burnt out then channel 2 on the internal amp of the radio. If you are looking for another Jensen as a replacement they are decent for a lower priced radio.
However if you are not operating your boat on salt water you could use a regular car unit. I replaced the radio in our boat with an generic import and I couldn't be happier.
I bought something similar to this model here
http://www.mp3playerstore.com/stuff_you_need/dvd/DVD-392.htm
not bad for just over 100 bux add 150 for a LCD and watch TV and dvd's in the boat too! although if your lake house is like mine there are only 2 channels to watch :(
Hack
Jensen vm0312 is on, but tray will not flip up
It sounds like there may be an issue with the mechanical components of the DVD player, specifically with the tray. Here are some troubleshooting steps you can try:
- Check to see if the emergency eject feature is working. There should be a small hole on the front of the DVD player, and you can use a paperclip or a similarly sized object to push the button inside. This should manually eject the tray.
- Make sure that the DVD player is receiving power. Double-check all of the connections and fuses.
- Reset the DVD player by disconnecting the power for a few minutes, then reconnecting it and trying again.
- If none of the above steps work, it may be necessary to take the DVD player apart and check the mechanical components for damage or wear. However, this is not recommended unless you have experience with electronics repair.
If none of these steps resolve the issue, you may need to seek the assistance of a professional electronics repair technician.
