20 Most Recent Jensen MP5610 CD Player Questions & Answers
manual
0answers
I need to know where the ground wire goes in the
All car stereo's are internaly grounded, so just connect the ground wire to the stereo chasis.
7/13/2011 3:25:15 AM • Jensen MP5610 CD... • Answered on Jul 13, 2011
How to remove
just take out the whole dash kit and then you will be able to take it out
9/2/2008 7:19:40 AM • Jensen MP5610 CD... • Answered on Sep 02, 2008
Installation
you are better off getting the wire harness for your vehicle goto circuit city they will have the wire harness you need and the smart cable for the jensen head unit so there will be no cutting just plug it in and go what is the make and model and year of your car ?
9/2/2008 6:20:32 AM • Jensen MP5610 CD... • Answered on Sep 02, 2008
Set time and date
Hi. I found a link to your owners manual. It is in pdf format.. http://www.audiovox.com/manuals/owners/MP5610_122304_final.pdf (dont be thrown off audiovox and jensen are one in the same company) PLEASE RATE ME 5 stars when you are done!!! ---ampman
8/24/2008 3:48:33 AM • Jensen MP5610 CD... • Answered on Aug 24, 2008
Dysfunctional Head Unit?
Try a non burned cd and see if it works if not then take it back
7/30/2008 8:35:42 PM • Jensen MP5610 CD... • Answered on Jul 30, 2008
Radio in, radio out
#1 Check you antena cord it may just have come unplugged, or it could be the tuner in the cd player went out too. but id checl antena first!
7/30/2008 8:34:53 PM • Jensen MP5610 CD... • Answered on Jul 30, 2008
Clock on car radio
Hi blackie - I could tell you how to do it but I believe it is easier if you look at the manual with the pictures. Below you'll find a link for your manual. After clicking on the link just click on manual for MP5610 next to the red dot. It's in English and Spanish but it's ok to read it. I believe you want pages 9 and 10 for the menu and the clock. If this solves your problem PLEASE rate this as fixed. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
http://mobile.jensen.com/jensen/JensenInfo.do?findManual=MP5610&x=4&y=7
Jeff
5/15/2008 11:48:41 PM • Jensen MP5610 CD... • Answered on May 15, 2008
Cd's player wont work quite right
u need to manually clean the lens using cotton buds(no fluid or solution) extra care! hope this help u...
5/15/2007 8:52:00 AM • Jensen MP5610 CD... • Answered on May 15, 2007
Time change!!
If you hold the D button in for 3 seconds then a menu appears. Press the button until the clock setting comes up. Now you use the dial button to set the time. Turn one direction to set the minute and turn the dial in the other direction to set the hour. Hope this helps!
1/28/2007 11:08:34 PM • Jensen MP5610 CD... • Answered on Jan 28, 2007
I have a Jensen JMS7010 marine radio it has water in the face I want to take it apart and dry it out and try to save the radio but it want come apart how can I dry it out or take it apart?
hair dryer if just moisture if water [failed seal or damaged cover ] and need to unscrew ans pry apart --but if water most likely electric circuit damage
4/17/2023 12:21:15 PM • Jensen Car Audio... • Answered on Apr 17, 2023
Wiring diagram Jensen eoa 7p seven band speaker wires.
Your Jenson model as written only appears here on Fixya in your question. The Jenson modelling numbers don't follow what you wrote so your model number 'EOA 7P' is not valid. https://www.google.com/search?q=jensen+eoa+7p ..
4/11/2023 6:17:33 PM • Jensen Car Audio... • Answered on Apr 11, 2023
Jensen vm0312 is on, but tray will not flip up
It sounds like there may be an issue with the mechanical components of the DVD player, specifically with the tray. Here are some troubleshooting steps you can try:
  1. Check to see if the emergency eject feature is working. There should be a small hole on the front of the DVD player, and you can use a paperclip or a similarly sized object to push the button inside. This should manually eject the tray.
  2. Make sure that the DVD player is receiving power. Double-check all of the connections and fuses.
  3. Reset the DVD player by disconnecting the power for a few minutes, then reconnecting it and trying again.
  4. If none of the above steps work, it may be necessary to take the DVD player apart and check the mechanical components for damage or wear. However, this is not recommended unless you have experience with electronics repair.
If none of these steps resolve the issue, you may need to seek the assistance of a professional electronics repair technician.
2/24/2023 9:31:14 PM • Jensen Car Audio... • Answered on Feb 24, 2023
Can I use a 270 watt amp kit on a JENSEN 1000 WATT AMP
No, you cannot use a 270 watt amp kit on a 1000 watt amp. The wattage of the amp kit must be equal to or higher than the wattage of the amp it is being used for.
2/22/2023 7:13:10 PM • Jensen Car Audio... • Answered on Feb 22, 2023
I request a schmatic picture
This video may help you https://www.youtube.com/watch?v=VC89DgWJlYw
10/24/2022 1:16:31 PM • Jensen Car Audio... • Answered on Oct 24, 2022
What gauge power wire do I need for my 1200 watt Jensen octane amp
1200 Watts at 12volts is 100 Amps. At least 16mm on a short run.
10/15/2022 12:35:41 PM • Jensen Car Audio... • Answered on Oct 15, 2022
HOW TO SET TIME ON JACOB JENSEN ALARMCLOCK
7/21/2022 2:40:03 PM • Jensen Car Audio... • Answered on Jul 21, 2022
Jensen MP5610 CD Player Logo
Popular Tags
13 questions posted
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
set time date
  • Car Audio & Video
