Wiring Diagram / Color Codes
1. Power Antenna (dark blue wire) - Connect to power antenna or amplifier.
2. Ground (black wire) - Connect to ground terminal or clean, unpainted part of chassis.
3. Memory/Battery (yellow wire) - Connect to battery or 12 volt power source that is always on. The radio will not work if this wire is not connected.
4. Accessory/Ignition (red wire) - Connect to existing radio wire or radio fuse.
5. Left front speaker - White/Black is negative, White is positive
6. Right front speaker - Gray/Black is negative, Gray is positive
7. Left rear speaker - Green/Black is negative, Green is positive
8. Right rear speaker - Violet/Black is negative, Violet is positive
9. RCA Outputs to Amplifier - Black is front, Gray is rear
10. Auxiliary Input Cable
11. Subwoofer Output
12. Antenna
13. CD Changer
The manual is available here:
http://diversesolutions.org/files/CD4610.pdf
The wiring diagram is under the section Wiring.
I’m happy to help further over the phone at
https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
