20 Most Recent
Jensen CH6001 CD Changer Questions & Answers
No Instruction sheet
This should help you!
As for the remote - see if the cable is hooked up to the readio or modulator. If so press the reset on the back of the remote.
Jensen UCH 6006 cd changer
This is the wiring diagram for the RF modulator. Not sure if this helps or not - the wire colors should be the same as what you are asking for.
Jensen vm0312 is on, but tray will not flip up
It sounds like there may be an issue with the mechanical components of the DVD player, specifically with the tray. Here are some troubleshooting steps you can try:
- Check to see if the emergency eject feature is working. There should be a small hole on the front of the DVD player, and you can use a paperclip or a similarly sized object to push the button inside. This should manually eject the tray.
- Make sure that the DVD player is receiving power. Double-check all of the connections and fuses.
- Reset the DVD player by disconnecting the power for a few minutes, then reconnecting it and trying again.
- If none of the above steps work, it may be necessary to take the DVD player apart and check the mechanical components for damage or wear. However, this is not recommended unless you have experience with electronics repair.
If none of these steps resolve the issue, you may need to seek the assistance of a professional electronics repair technician.
