20 Most Recent
Jensen RF10DC 10 CD changer Questions & Answers
My Jensen RF10DC has stopped working. It's
Dear edbobsall,
there is an inline fuse for that unit (more than likely tucked behind the radio) check that first. if its not there, just trace the wire back (from the changer) to its power source and see if that is getting power, there might be a factory fuse blown...
My RF10DC stopped working.
if i remember correctly there is an inline fuse for that unit (more than likely tucked behind the radio) check that first. if its not there, just trace the wire back (from the changer) to its power source and see if that is getting power, there might be a factory fuse blown... let me know what you find. As for a replacement controller, i would contact Jensen directly, most of the time they can sell you one for a reasonable price. Why makes you suspect the controller, does the unit seem like it is still functional?
I need the guts
the changer has been discontinued so ebay or craigslist as even Jensen says they dont have it.
The Remote
I also did some calling locally and some suggested I call Circuit City. They said to come over, that they will look at it, but do not carry the Remote . A gentleman came out and checked and ended up taking the panel off dash and discovered it wasn't a problem with the remote, but a casting, which was plastic, that surrounded a fuse was broke, so there was no connection. He was able to replace that and I'm back in workin order! I want to thank Circuit City , they were wonderful to me and the tectnician was very knowledgeable---so good to have the player running again!!
RF10DC Changer
Extreme Sound WMS6100RW use the same controler & fm modulator
Remote Control
After doing some searching, I have come to the conclusion that this remote is No Longer Available for this unit. There is however a company that speacializes in suppling remotes for consumers that are no longer available. You will have to go to the link I am suppling, and leave the information on a request sheet and they will get back in touch with you on a price and availability. Good Luck GO HERE
http://www.nlaremotes.com/request.htm
SEEKING DATA CABLE FOR JENSEN RF10DC
Go to this link and click "find a manual";
http://www.audiovox.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=13670&langId=-1
It is not for your model exactly, is for a rf10ch, but look on page 12 it shows the standard cable for this sort of unit - it looks like a 15 ft standard din 8-pin (7/1/315) connector. The cable should be well shielded. With this information any electrical shop should be able to make one up.
or contact these guys - they have taken over customer service from jensen, but i am unsure how good they are - please post back if you have any feedback on this.
Hope this helps :)
Replacement cartridge
you can call the product manufacture. The number is in the product page under contact information.
Daniel
