20 Most Recent Lenovo ThinkCentre A55 8705 - Pentium Dual Core E2140 1.6 GHz (870502U) PC Desktop Questions & Answers
Error 00ce machine type and serial number are invalid
??? ?????? 00ce ?????? ? ???????? ????? ??????????????,Lenovo ThinkCentre 92m 03T6821 Intel Socket LGA1155
6/17/2017 6:03:33 PM • Lenovo... • Answered on Jun 17, 2017
0answers
ERROR CODE 00CE
Be the first to answer 1/27/2014 9:49:00 AM • Lenovo... • Posted on Jan 27, 2014Be the first to answer
MOTHERBOARD 39J6196 41T3044 Front Panel Pinout
sorry we never saw the instruction sheet for this
7/27/2021 8:55:39 PM • Lenovo... • Answered on Jul 27, 2021
I order a lenovo thinkcentre m92p i7-3770 and when i went to system it said manufactuer was hp
Please check with the Seller or use the Serial No. to track the exact info of your Laptop.
9/20/2016 6:35:27 AM • Lenovo... • Answered on Sep 20, 2016
How do i unlock my keyboard
Back up all your data and do a system restore
5/13/2016 6:26:01 AM • Lenovo... • Answered on May 13, 2016
2answers
Motherboard smoke when switch on CPU damage power connector on board
I would replace the whole power supply. You don't want to give it a chance to short out the board. If this is a just a run of the mill business machine the power supply should only be around 50.00 or less depending on where you find it.
4/14/2016 2:22:56 PM • Lenovo... • Answered on Apr 14, 2016
Processor socket i got 7 pins damage how can i fix
If the pins are bend straighten it using squeezer
4/14/2016 2:26:26 AM • Lenovo... • Answered on Apr 14, 2016
Auto processing
The auto processing is the monitor trying to adjust to a particular resolution. To help you control display quality, please follow the steps given below: -Open the 'Display Quality troubleshooter' by clicking the Start button, and then clicking 'Control Panel'. -In the search box, type 'troubleshooter', and then click 'Troubleshooting'. -In the left pane, click 'View all', and then click 'Display Quality'. GuruAid.com
3/21/2016 7:05:57 AM • Lenovo... • Answered on Mar 21, 2016
4answers
Need help I dont have my Lenovo k330 7727motherboard manual need the order for my front panel, changed my case now stuck.
I read that the motherboard for this PC is an Asus P67 B3 (http://www.techspot.com/review/424-lenovo-ideacentre-k330/) (However the picture of the inside of the PC doesn't look like the picture o the Asus website, so this may not be right, although the schematic in the Lenovo hardware replacement guide does http://download.lenovo.com/UserFiles/UserGuide/en/User%27s%20guides%20and%20manuals/K330/Lenovo%20IdeaCentre%20K3%20Series%20Hardware%20Replacement%20Guide%20V4.0%20(English).pdf) The information you need ought to be in the manual which is available as a download from the Asus website here https://www.asus.com/Motherboards/P8P67/HelpDesk_Manual/ 19.January.2015
5/13/2015 7:42:14 AM • Lenovo... • Answered on May 13, 2015
I am having a Problem with my video card not letting me run an addition monitor off the vga output on the motherboard. I know it works because I can go to the bios and change it and it works but they
When using a PCI or PCI-E graphics card, it will disable your standard VGA output port because the up-dated graphics card and your factory VGA port require different display drivers. Usually, the drivers are conflicting and will make your system unstable and cause it to crash. In short, you can't use both at the same time. I have a Radeon HD 5450 graphics card installed on my PC and it too has disabled my standard VGA port. If you are trying to use more than one monitor, you have to install a graphics card that supports a multiple display output. The graphics card will either have 2 VGA ports, 2 DVI-D ports or 2 HDMI ports or even any combination of the 3. My card, for example, has 1 VGA, 1 DVI-D & 1 HDMI. I can run up to 3 monitors at a time via my graphics card, but I cannot run a 4th monitor from my factory VGA port. My graphics card uses ATI/AMD drivers while my VGA port requires the use of Nvidia drivers. I hope that you find this useful.
4/5/2015 9:37:26 PM • Lenovo... • Answered on Apr 05, 2015
Have a Lenovo USFF 7479 Build and can not find display drivers for Linux Zorin 9 Ultimate as only Windows display drivers are available.
Then you have to go back to the distributors of this Linux distribution and list the drivers for the items you need. Linux drivers are open source programs, so the drivers from one computer can be complied into another distribution, if they use the same chips. The manufacturers such as Lenovo rely on third parties to provide any software that they do not support, they do not have to write them.
2/25/2015 1:12:50 PM • Lenovo... • Answered on Feb 25, 2015
How do i use the @ key on a lenovo lxh-ekb-10ya keyboard
Check that you have the right keyboard language enabled. Hold Windows key and press Space until it says English (US).
2/21/2015 6:23:07 PM • Lenovo... • Answered on Feb 21, 2015
Keyboard & mouse error
We need more info. Mouse and keyboard error doesn't help.
2/11/2015 8:49:28 PM • Lenovo... • Answered on Feb 11, 2015
2answers
My disc is not playing nor can I eject it is there some way I can do this I have a Lenovo Think Centre M90z
The drive can be easily removed once removed you can then use the paper clip from the back and push the tray open
1/5/2015 3:41:04 PM • Lenovo... • Answered on Jan 05, 2015
I reach aol through internet exploer...my buddy list is missing...no icon shows
The Quick Contacts button on the left will lead you to "Open Full Contacts". If none are listed, you need to export them from AIM or wherever they currently reside, as a CSV, TXT or LDIF file, then Import using the Tools button within AOL Mail.
1/3/2015 1:12:17 AM • Lenovo... • Answered on Jan 03, 2015
Where can i find an l-i945e manual? help me pls.
If there's a manual for the motherboard then it should be here: http://support.lenovo.com/gb/en
11/7/2014 9:28:17 PM • Lenovo... • Answered on Nov 07, 2014
2answers
What does computer command "ipconf/release" do?
This command will flush the IP address from an active connection. The correct syntax is ipconfig /release *con* which will release all connections. If you just want to see if you can get a new address then use ipconfig /renew
11/3/2014 10:36:12 AM • Lenovo... • Answered on Nov 03, 2014
Lenovo ThinkCentre A55 8705 - Pentium Dual Core E2140 1.6 GHz (870502U) PC Desktop Logo
3 questions posted
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
ThinkCentre Lenovo
  • ThinkCentre Lenovo
Most Popular Question
error 00ce machine type serial number
  • Computers & Internet
