20 Most Recent Jensen VM9410 Car DVD Player Questions & Answers
How to connect a camera back reverse on nsdn-w59
how do u fix reverse camera for nsdnw59 in toyota allion
9/7/2018 5:14:41 PM • Jensen VM9410... • Answered on Sep 07, 2018
Need code for jensen VM9412
the code is 012345 12345 or 0123456 or 123456
Good luck.
2/16/2018 6:06:39 AM • Jensen VM9410... • Answered on Feb 16, 2018
2answers
Wire diagram i think
pink wire if its to go to ground then any metal is ground or negative not live in other words they say the handbrake so you cant use it whilst driving so any metal should do for this ok.
Are you wiring it to amp or not?
Also the mute only wires into say phone cradle or something that would mute the stereo say if you had phone in craddle this would mute the sound so you could here the call. so not needed unless you have phone craddle.
If the two lives are wired in and the ground black when you earth the pink then it should switch on let me know if this happens.
Auto ant is for the arial on car if this goes up and down on motor if not then its not needed
Ill check on dimmer/illumination ok but bare with me for couple of hours just popping out but will get back to you then ok
1/6/2013 6:05:37 PM • Jensen VM9410... • Answered on Jan 06, 2013
3answers
Jensen 9410 will not load or eject
i had my jensen three weeks everything was okay until all of sudden the unit wounld not load or eject CD's or DVD's
9/13/2012 6:40:04 AM • Jensen VM9410... • Answered on Sep 13, 2012
What is ill stand for on a stereo harness
ILLUMINATION
8/21/2012 11:01:32 PM • Jensen VM9410... • Answered on Aug 21, 2012
Whenever I turn on my
code is either 543210 or 012345 make sure the yellow wire is on a constant power source and the red is connected to ignition on and of course black is ground
8/19/2011 4:58:59 PM • Jensen VM9410... • Answered on Aug 19, 2011
WHERE CAN I GET MY
try going to audiovox.com and see if they can help you. Audiovox owns Jensen.
7/7/2011 4:38:14 PM • Jensen VM9410... • Answered on Jul 07, 2011
I know that I need
  • For this you really need to contact Jensen directly and order one from them. I have the link set to your unit @ Jensen's website http://mobile.jensen.com/search/?sku=VM9410 You don't want to take a chance with some cheap aftermarket cord with a $650usd deck.
regards, Tony
5/24/2011 6:58:08 AM • Jensen VM9410... • Answered on May 24, 2011
Is there a way to make player play without hooking
The e-brake wire is there for liability reasons. If you're in an accident and there is a video playing, you will probably be liable. Also, it is illegal almost everywhere to have a video playing that can be viewed by the driver. This could get you pulled over and fined. This is why the brake wire is there, so the player knows the vehicle is not moving.
5/9/2011 8:17:08 PM • Jensen VM9410... • Answered on May 09, 2011
0answers
I got everything hooked up.the video is playing
Hello... sorry to hear you are having a problem. There should be a wire on the back of the headunit that is marked "brake". This wire is usually green or pink. You will need to hook the wire marked "brake" together with the black "ground" wire. This should allow the screen to play without the brake being engaged. If this does not work, let me know and I will give you a sequence route to fix the problem.
20 year car audio/video installer
Bay manager
3/16/2011 8:22:10 PM • Jensen VM9410... • Answered on Mar 16, 2011
Dvd player does not show
The green parking brake wire from the Jensen unit needs to be connected to chassis ground. This will enable the viewing of DVDs.
3/9/2011 1:08:39 AM • Jensen VM9410... • Answered on Mar 09, 2011
How do i connect my
You will need an Apple AV cable to connect to the rear of your reciever
See page three in the manual for further instruction
http://audiovox2.info/docs/common/VM9410/VM9410_OM.pdf
3/7/2011 11:15:30 PM • Jensen VM9410... • Answered on Mar 07, 2011
How do I get my iPhone to connect to my Jensen
You will need an Apple A/V cable to plug into the AUX in the rear of your reciever.
Here is the Owners manual for further info
3/7/2011 10:55:52 PM • Jensen VM9410... • Answered on Mar 07, 2011
Yellow wire on a jensen
There should be some sort of indication of the wiring on the unit, sometimes on a label, sometimes moulded into a plastic panel on the back.
Might be power (+)
3/7/2011 2:23:03 AM • Jensen VM9410... • Answered on Mar 07, 2011
Jensen VM9410 Car DVD Player Logo
157 questions posted
Top Jensen Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Car Audio & Video
Most Popular Question
know need
  • Car Audio & Video
