20 Most Recent
Jensen JS1000-A Subwoofer Questions & Answers
No sound
Chances are the main output semi-conductor has failed. It will be largest of the parts and might be on a heatsink. If it is an IC, 9 times out of 10, I would say it's gone.
Subwoofer just stopped working. There's power but no sound.
I have the same problem. My guess is that the subwoofer coil is messed up. You MIGHT have to get it recoiled. But before you do any of that get someone with a sub to play their sub in your car, if it works.... then your sub is messed up, if not.....then your amp is messed up ( trial and error ). Today i noticed my subs rubber surrounding is crooked, that may be the problem for me. Also when I press down on the sub it makes a sticking sound, like something came loose. So once i get everything opened and out ill let you all know the solution. Good Luck!
How to set time on jensen jcr-425
To set the time on a Jensen JCR-425 clock radio:
- Press and hold the "Time Set" button until the display flashes.
- Press the "Hour" and "Minute" buttons to adjust the time.
- Press "Time Set" again to confirm.
Jensen Compact Disc Music system JMC-500W. Open/Close button not opening the lid
Please hold down the open/close button instead of just pressing it. Then you can press the lid while this is happening. I think you might already suspect this, but it sounds like the hook that connects to a portion of the lid isn't unhooken during the button press. Friction might be a cause or the hook-movement might not be functioning as smoothly due to other factors.
If the issue continues, we might have to consult Jensen on a potential repair/replacement of the item as well.
