20 Most Recent Jensen JHT525 System Questions & Answers
if it is a powered sub you should lift the ground. you can do this by adding a three prong to two prong adapter. you know, like when you go to plug something in and the cord your plugging in has three prongs and the outlet your plugging in to only has two. it doesn't have the hole for the ground so you go get a little grey adapter that has three holes on one side and two prongs or tabs on the other.if that doesn't take the hum out (actually, is keeping the hum from getting in) you have a problem with the amplifier.
Jensen JHT525... | Answered on Dec 12, 2018
Both resistors are: 1/4w 100 ohm with 5% tolerance (brown, black, brown & gold colors). Best to use the "Metal Film" type because they're more durable than the "Carbon Film" type.
Jensen JHT525... | Answered on Oct 16, 2016
Based on your description, the internal power supply of the subwoofer amplifier would be suspect. Often it would be a blistered or leaking filter capacitor. It is a relatively easy/inexpensive repair.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Jensen JHT525... | Answered on Jun 04, 2011
i have the same problem..god damn it..
Jensen JHT525... | Answered on Dec 26, 2010
NEEDED TO BE REPLACED
Jensen JHT525... | Answered on Aug 08, 2009
I had this problem, too, and ended up throwing away the subwoofer. The reason in my case was the amplifier had a blown resistor. I could clearly see the burn marks and the broken resistor. I could have fixed it, but the subwoofer is 9 years old.
To find this, I unscrewed all of the bigger screws on the back except the two with the "ring" around the screw head. I then unscrewed all of the small screws. The amplifier/controller will come apart. Disconnect the speaker from the amp and then open the amplifier itself. In the "box" you will see a metal bracket, which was where the burnt resistor is.
Hope this helps.
Jensen JHT525... | Answered on Jun 14, 2009
Sounds like your connection is bad on the wiring to the Subwoofer. Try rewiring the connection with new wire.
Jensen JHT525... | Answered on May 31, 2009
hi,i have 1000w 4 speekers but i have one amp.how do i connect to that?
Jensen JHT525... | Answered on Mar 22, 2009
plug your low input into the subwoofer output of your reciever.that should get the sub working then you have to run speaker wire from your speaker outputs on your reciever into your sub in the top row of inputs then the outputs on the back of sub(the bottom row of speaker hookups go out to your speakers....my email is bsharp76@hotmail.com if you still cant get it i can talk you through it on there or ill give you my instant messenger name is you still have problems good luck,b
Jensen JHT525... | Answered on Mar 07, 2009
I always type in the make and model on Google and most of the time I find an online manual.I've had some really oddball stuff but found manuals for em.
Jensen JHT525... | Answered on Dec 03, 2008
If you have cables hooked up and have not installed them to the components when turned on the speaker will hum.
If your electrical outlet is not grounded properly you speaker will hum.
Personally I'd take it back and get a new one. if you just purchased it.
If this happens again try a grounded curcit first then go from there.
Jensen JHT525... | Answered on Jun 24, 2008
Jensen JHT525 System Logo
Popular Tags
20 questions posted
Top Jensen Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Jensen Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Audio Players & Recorders
Most Popular Question
loud humming noise from subwoofer
  • Audio Players & Recorders
