20 Most Recent
Sony VGN-Z520N/B PC Notebook Questions & Answers
Sony vgn-z520
Usually, it is not possible to upgrade the cpu on a laptop. In rare cases where it is possible the upgrade usually costs nearly as much as a new laptop.
However, you can significantly upgrade the laptop's performance by adding more memory and by replacing the old slow hard drive.
Your Sony VGN-Z250 is usually supplied with 3GB of RAM memory. You can replace the existing memory modules with a new kit consisting of 2 x 2GB modules (total 4GB). The type of memory you need is "SO-DIMM" (meaning laptop size) DDR3 - 1066MHz (you may use 1333MHz memory but it will only run at 1066MHz speed). I would suggest either G-Skill or Crucial brand memory. And you can replace the hard drive with an SSD. You'll be amazed at the boost this provides, seriously. I would suggest either Samsung 840 EVO or Sandisk Ultra for an SSD. Both offer super-fast performance compared to your old spinning hard drive, and both have very low power consumption so they run cool and give your laptop a few extra minutes of battery power. You can clone/copy your existing Windows setup onto the SSD using free Macrium Reflect software or free software from the SSD maker's website. Or, you can do a fresh install of Windows.
Want to upgrade from vista to windows 10
The Microsoft website will give details of how to upgrade and the costs involved, though buying the new operating system on hardware and performing a drive format and a clean new load could make more sense.
A computer that previously ran Vista will probably be a few years old and therefore have a low specification so you could be disappointed with the performance when running Windows 10.
I have a very old pc originally running Windows 95 that copes well with XP without perceptible loss of functionality for modest purposes, which makes no sense at all.
On the other hand a relatively high-spec laptop I own needs a fair amount of patience running Windows 7.
You have to try these things but the results aren't assured and it is a bit like making a wager with your cash. Might be more economic to buy an up to date machine.
11/23/2015 2:17:18 AM •
Sony VGN...
Answered
on Nov 23, 2015
How do i send photo files that are on my laptop without losing the pictures
Hi Irene - There are many ways to send photos and so I am assuming you are sending them by email. If this is not correct, please provide more info. Within your email program send a new message. In the new message, click on Attach File or Insert Picture. Which ever you choose, it will open a box that will allow you to locate your photo files on your laptop. Select the ones you want and they will be added to the email. They will also remain intact on your laptop. Hope this helps. Thanks.
1/20/2015 4:48:03 PM •
Sony VGN...
Answered
on Jan 20, 2015
Sony vaio brightness
Look for a setting along the lines of
control panel -> display -> find the word "gamma" in there somewhere and turn all the way up
4/12/2014 5:00:29 AM •
Sony VGN...
Answered
on Apr 12, 2014
Left speaker not working
look by your clock and you see and speaker symbol cick on it and then click on mixer!!!!
1/13/2014 7:30:58 AM •
Sony VGN...
Answered
on Jan 13, 2014
Speaker not working
Looks like the problem is not the speaker is the microphone. You need to go to Control Panel then Sound and click on Recording tab.You need to be able to see the Microphone setup, you need to configured it. Good luck!
11/13/2013 9:53:11 PM •
Sony VGN...
Answered
on Nov 13, 2013
