20 Most Recent Kenwood KDC-319 CD Player Questions & Answers
Unfortunately Kenwood codes are only available from the Main Dealer or by using a Radio Decoding Service who will connect a laptop to read the working code inside your radio`s memory chip (EEPROM)
Kenwood KDC-319... | Answered on Mar 13, 2015
Red is Positve = +
Black is negative = -
Yellow is the backup - If the backup is not connected, the radio station will lost it memory if ignition is turned off, and cd will start from no 1 and won't continue when it was last played. - Yellow must be connected to the Battery or positve wire which does not switch off if the inition is off
Kenwood KDC-319... | Answered on Oct 02, 2014
You would have to call Kenwood directly, and provide them with a valid proof of purchase. Once they have your information, they can provide you with the code.
Kenwood KDC-319... | Answered on Jul 12, 2014
www.radio-code.lt mint web page mate
Kenwood KDC-319... | Answered on Nov 30, 2013
Kenwood adapter looms are readily available from your local Auto Accessory store, of from Ebay.
These are a 'plug & play' solution (pre-wired), which eliminates the need to cut any of your existing vehicle's wiring.
Ideally, you want a single adapter loom with Kenwood plug on one end, with your vehicle's "factory" plug on the other (all common brands are available).
e.g. Kenwood ---> Ford; Kenwood ---> GM etc etc
Cheers,
Kenwood KDC-319... | Answered on Mar 14, 2013
Kenwood head units show "protect" when there's a problem with the speaker outputs. This might mean a shorted speaker wire, a blown speaker, or an internal defect in the head unit. Once the condition that's causing the "protect" mode is fixed, the CD player should be back in normal mode the next time you turn it on.
If it's staying in "protect", then you'll definitely have to remove the stereo and do some troubleshooting to fix it. Many car audio stores will do system troubleshooting, for a fee. If you want to do it yourself, here's what you need to do:
Pull the Kenwood unit from the dash and disconnect all the speaker wires. Turn it on and see if the "protect" message displays. If it does, the stereo has an internal defect and will need to be serviced. If it doesn't, then turn it off, and re-connect one speaker. Turn it on again and see if it displays "protect".
If it works with a single speaker connected, keep re-connecting the others until you identify the speaker that's causing the problem. There may be a wiring problem or defective speaker in that location.
If it displays "protect" with a single speaker connected, then disconnect that one and try a different one. If all the speakers cause a "protect" mode, then you're probably back to a defective head unit, unless your friend managed to blow all your speakers at once.
Thanks,
Kenwood KDC-319... | Answered on Dec 02, 2012
I would start by disconnecting the radio and hooking it up right,the power should go through the ignition switch.So that when you turn the car off the radio will go off and to hear it on again you have to turn the key to accessory or start it.That might take care of a few of your problems.
Kenwood KDC-319... | Answered on Jun 25, 2012
Your code is 8315
Kenwood KDC-319... | Answered on Nov 05, 2011
my CD player is Kenwood KDC-W3041 displayed protect and i can't turn it on. what can i do for that?
Kenwood KDC-319... | Answered on Jul 05, 2011
Kenwood KDC-319 CD Player Logo
87 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Mike Duncan
Mike Duncan
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
kenwood kdc 139 when its
  • Car Audio & Video
