20 Most Recent Kenwood KRC-508S Cassette Player Questions & Answers
I lost the papers to my stereo and I got it hooked
You will have to either find those papers or contact Kenwood, as these are your only two options my friend
2/8/2010 2:56:44 PM • Kenwood KRC-508S... • Answered on Feb 08, 2010
My kenwood kdc-u2159b display call n no sound out
Me radio kdc2159b is displaying the ward call,how do i remove it
4/14/2024 10:44:35 AM • Kenwood Car... • Answered on Apr 14, 2024
Reset a Kenwood 8070 without a remote?
To reset a Kenwood 8070 receiver without a remote, you typically need to locate the reset button on the device itself. This button is often small and recessed, so you may need a paperclip or a similar tool to press it. Consult the user manual or look for the reset button near the power or input/output ports on the receiver. Once located, press and hold the reset button for a few seconds until you see the receiver reset. Keep in mind that this process may vary slightly depending on the specific model of the Kenwood 8070 receiver.
3/6/2024 3:50:24 AM • Kenwood Car... • Answered on Mar 06, 2024
KDC-138 CD PLAYER/RECEIVER. What does code E-004 indicate?
Kenwood KDC-138 Instruction Manual [Page 18]
ManualsLib https://www.manualslib.com > ... > Instruction manual If the "E-99". code does not disappear, consult your. nearest service center. IN (Blink):. The CD player section is not operating. properly. ? Reinsert the CD.
My Kenwood KDC-d301 is giving me a E-4 error message ...
JustAnswer https://www.justanswer.com > car-electronics Aug 9, 2010 - Hello, The issue is most likely that the laser lens in the CD player itself is dirty, and not the disc. It may have been initially caused by a ... 1 answer · Top answer: You need the Kenwood radio keys that came with the unit to slide it out of the dash. It sounds ... Missing: 138 ‎' Show results with: 138
I have a KDC 138. It is stuck on OCER and will not reset.
JustAnswer https://www.justanswer.com > car-electronics > 5lw8u-... Sep 27, 2011 - This actually is DCER - you have a blown speaker. The radio is sensing a ground on the speaker circuit. Check that and let me know. If you leave ... 1 answer · Top answer: Thanks for stopping by: This actually is DCER - you have a blown speaker. The radio is sensing ... Missing: E- ‎' Show results with: E-
Cd Player Unit - Kenwood KDC-138/138CR Service ...
ManualsLib https://www.manualslib.com > ... > Service manual Kenwood KDC-138/138CR Manual Online: components description, Electric Unit, Switch Unit, Cd Player Unit. Controls Fm/Am Tuner, The Changer, Cd Mechanism, ...
2/16/2024 6:44:56 PM • Kenwood Car... • Answered on Feb 16, 2024
How to power supply of kCSWA900 Kenwood sub whooper power supply 10 pin
Take a look at this manual diagram. https://www.manualslib.com/manual/359815/Kenwood-Ksc-Sw10.html?page=5#manual Given the above is not your model, at least it shows the 10 pin. Ironically, below I offer a diagram of your model. The irony comes in the fact that the diagram appears labeled in Japanese But if you compare the two diagrams, maybe something will make sense from the one with the English labels. Otherwise, you might fire off a query to Kenwood customer support. https://www.manualscenter.com/manuals/kenwood/kscsw900-owner-manual.html Here is a 10 pin harness compatible with the subwoofer. Kenwood Subwoofer Amp KSC Wa100 Wa80 Sw10 10 Pin Harness for sale online ' eBay I don't have any information on how to power supply a kCSWA900 Kenwood subwoofer. However, I can tell you that the Kenwood KSC-SW10 compact powered subwoofer has a built-in amplifier with a 38 watts RMS power and a wired remote for control over volume level, variable low-pass crossover (50-120 Hz), and selectable phase control (0°, 180°) . The subwoofer comes with a power/ground wiring harness and preamp (RCA) and speaker-level inputs .
1/26/2024 3:58:54 AM • Kenwood Car... • Answered on Jan 26, 2024
2answers
I have 2 mtx 12"woofers (8ohms each wired parallel to get to 4ohms) which Kenwood amp would be best to use: kac-7252 or kac-9104d?
The Kenwood KAC-7252 and KAC-9104D are both great amps, but they have different strengths and weaknesses. The KAC-7252 is a 5-channel amp that can output 75 watts per channel at 4 ohms. It also has a built-in crossover and time alignment, which can be helpful for getting the most out of your woofers. The KAC-9104D is a 4-channel amp that can output 100 watts per channel at 4 ohms. It also has a built-in subwoofer output, which can be used to power a separate subwoofer. If you are looking for an amp that can power all of your speakers, the KAC-7252 is a great option. It is also a good choice if you want an amp with built-in crossover and time alignment. However, if you are looking for an amp that can power a subwoofer, the KAC-9104D is a better choice. It is also a good choice if you want an amp with more power output. Ultimately, the best amp for you will depend on your specific needs and budget. If you are not sure which amp is right for you, it is always a good idea to consult with a professional car audio installer. Here is a more detailed comparison of the two amps: Kenwood KAC-7252
  • 5-channel amp
  • 75 watts per channel at 4 ohms
  • Built-in crossover and time alignment
  • MSRP: $399
Kenwood KAC-9104D
  • 4-channel amp
  • 100 watts per channel at 4 ohms
  • Built-in subwoofer output
  • MSRP: $499
I hope this helps!
12/13/2023 2:44:37 PM • Kenwood Car... • Answered on Dec 13, 2023
3answers
- Kenwood KDC-X396 the Brown mute wire gets connected to what to get the phone to work through it
whatever makes it mute from whatever it is you are in
12/5/2023 7:21:12 AM • Kenwood Car... • Answered on Dec 05, 2023
MANUAL for kenwood dpx-6200m
12/5/2023 6:53:47 AM • Kenwood Car... • Answered on Dec 05, 2023
2000 Subaru outback w type c radio/CD/weather replacement
This often doesn't work because the radio is monitored by the Body Control Module on the 5 volt computer network. Wiring
Subaru Legacy, Outback, Baja (1993-2008) Car Stereo ...
Pinout Guide https://pinoutguide.com > ... > Subaru pinouts Oct 22, 2019 - Pin #. Function. Legacy / Outback / Baja Factory Radio Connector Wire Color (wires go to car's Speakers, etc.) Subaru After-market Harness ...
2000 Subaru Impreza Car Stereo Wire Colors and Locations
the12volt.com https://www.the12volt.com > installbay > stereodetail 2000 Subaru Impreza Stereo Wiring ; Left Front (-), Green/Black ; Right Front (+), Red/Yellow ; Right Front (-), White/Black ; Rear Speakers, 6 1/2" Rear Doors. Installation kits https://www.google.com/search?q=2000+subaru+outback+stereo+installation+kit ./.
11/4/2023 3:37:26 PM • Kenwood Car... • Answered on Nov 04, 2023
Kenwood pm900 got to keep my finger on the green buton to work
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=&cad=rja&uact=8&ved=2ahUKEwjVy_3gwJSCAxXPtokEHVevBRMQFnoECA8QAQ&url=https%3A%2F%2Fwww.fixya.com%2Fsupport%2Ft20296183-kenwood_pm900_only_runs_hold_green&usg=AOvVaw1SY6YdYg_TxXi9l6iEL8Xc&opi=89978449
10/26/2023 8:02:28 PM • Kenwood Car... • Answered on Oct 26, 2023
Kenwood DDX276BT car stereo. How to recalibrate without going into the settings
Question edited for clarity, add maker and '(what it is). Question moved from 'Initial Television' to Kenwood Car Audio. Do a Factory Reset. https://www.google.com/search?q=Recalibrate+ddx276bt+stereo ..
8/19/2023 6:40:11 PM • Kenwood Car... • Answered on Aug 19, 2023
Why not show CD track info on Kenwood c-h7 using dp-mh5 player? what error ? what should check?
The issue with not showing CD track information on your Kenwood C-H7 using the DP-MH5 player could be caused by several factors. To resolve this issue, you can check the following:
  1. Compatibility: Ensure that the DP-MH5 player is compatible with the Kenwood C-H7 unit.
  2. CD format: Ensure that the CD is in the correct format and meets the requirements for playback on the DP-MH5 player.
  3. CD read error: Make sure the CD is clean and free of scratches, as these can cause read errors that prevent track information from being displayed.
  4. Connections: Check the connections between the DP-MH5 player and the Kenwood C-H7 unit to make sure they are secure and properly connected.
  5. Software/firmware: Make sure that both the DP-MH5 player and Kenwood C-H7 unit have the latest software/firmware installed and are up to date.
If these steps do not resolve the issue, you may need to seek further assistance from the manufacturer or a professional repair service.
7/27/2023 9:57:24 AM • Kenwood Car... • Answered on Jul 27, 2023
How do i change language on kenwood MDV-Z704W
7/26/2023 1:49:04 PM • Kenwood Car... • Answered on Jul 26, 2023
My Kenwood home stereo keeps powering off when I power it on and blinking re
Sounds like the output stage or power supply has been damaged. Time to take it to an authorised repair agent to get it going again.
7/19/2023 5:45:10 PM • Kenwood Car... • Answered on Jul 19, 2023
Kenwood excelon x897 buttons stopped working
6/16/2023 4:05:16 PM • Kenwood Car... • Answered on Jun 16, 2023
Kenwood KRC-508S Cassette Player Logo
Popular Tags
3 questions posted
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Car Audio & Video
Most Popular Question
lost papers stereo got hooked
  • Car Audio & Video
