20 Most Recent
Kenwood KDC-128 CD Player Questions & Answers
:I shorted out my kdc 128 head unit and i switched all the fuses but it still wont turn on. any ideas?
Firstly, the main wires from the KDC-128 you need to check are:RED - this should be connected to the vehicle's +12v IGNITION wire.YELLOW - this should be connected to the vehicle's =12v BATTERY wire.EARTH - i) some tuners will only earth when the tuner itself, is screwed into the vehicle's chassis (i.e. a metal mounting bracket); ii) some tuners require the BLACK wire to be attached to the vehicle's chassis (i.e. a metal mounting bracket).Secondly, if the above wires are connected correctly, then you should suspect the fuse on rear of the tuner has blown (even if it LOOKS ok). Replace and see what happens.Thirdly, if all above are ok, then you have a short somewhere on the vehicle.
Can get kenwood kcd 128 to turn on
ok black is ground, red is remote, yellow is battery, orange is illumination, make sure the antenna wire is in and you hold down the SRC button for about 3 to 5 seconds. please vote.
I hooked up my kenwood kdc 128 cd player and nothing works
i had the same problem as you, i own a 98 ford escort, and i couldnt find a wiring diagram that matched the ones in my car . i managed to connect the constant (red) and switched (yellow) to the wires in the car but i had made a mistake with the ground (black) . so i re connected it to where its suppose to go so now the head unit actually lights up and turns on.
now i have another problem because my head unit doesnt stay on for any longer than 1 mintute
Got a new Kenwood KDC-128
you need to hook the yellow wire off the back of the radio up straight to the battery this keeps memory power to the head unit then wire the wires in color coded sequence red to red black to black so on and so forth if this doesnt fix it you might want to think about replacing head unit
Kenwood kdc-128
The remote lead on the back of the radio should be a blue wire with a white stripe. If this wire is not present, then you can use an accessory lead in the car or the accessory lead (red) at the radio harness. Hope this is helpful.
Im loose my wires
Here you go:
This is the wiring diagram for most all the kenwood radios for the last few years. Yours included.
If you need more help just ask.
A good rating would be appreciated.
Clock
you have to get into the menu. Here is a link to the manual to help you do it.
http://inform2.kenwoodusa.com/manuals/KDC1028.pdf
KDC 128 CD Player
It could be that the player is going into protect mode. This is normally due to a short in a speaker cable, or one or more of your speakers is blown.
Try disconnecting all of your speaker cables at the speaker end and make sure the connectors don't touch. Power it up again and see if it stays on. Bear in mind you won't hear anything.
If it powers up. Carefully plug each speaker back in. It will power off if you plug in the dud!
If it still doesn't power up. disconnect all of your speaker cables at the player end.
If it powers up this time one of your cables is shorted. Same as the speakers, plug one pair of wires in at a time to find the dud.
If it's still switching off. It could be a blown circuit on the output stage of the amp.
Here's a silly question.
Does the player get hot?
All this assumes that you have had this player working with these cables and speakers before.
If not check that the speakers are the correct rating (Resistance in Ohms) for the player.
And lastly here's where you can get a manual
http://www.kenwoodusa.com/Support/Car_Files/#_
No sound from speakers
Check the value of the fuse for the power feed, it could be that the fuse is to low.
The unit uses 10A min. I suggest a 25A fuse.
here's a manual
http://inform2.kenwoodusa.com/manuals%5CKDC1028.pdf
Luck
