20 Most Recent
Kenwood eXcelon KDC-X679 CD Player Questions & Answers
I just put my old
take the blue/white wire coming from the radio and tie that in with your solid blue wire coming from the radio and which is connected to whichever wire in the car. So in total you'll have 3 wires at a connector.
Set clock time kenwood car radio
Get into (standby mode) by hitting source (src) button until screen says "Standby".
M.Jog key is to the left of the (src) button. Hold it in for more than 1 sec to get into menu mode.
Move Toggle Control Knob (TCK) up (don't turn) until you see "Clock Adjust" on the screen.
Press Toggle Control Knob (TCK) in for more than one second and the time will appear (flashing).
Move TCK up/down for hours, left/right for minutes (again, don't turn knob).
Press (src) button when the desired time is selected.
I just bought a 1994
You can enter a 4-digit security code which must be used when the unit is removed from the vehicle, or the constant power source is disconnected from the unit. When constant power is restored to the unit, the security code must be entered before the unit becomes operational.
If the code is lost or forgotten I am afraid the unit has to go to a Kenwood dealer for re-coding.
How do i set the clock
Manual Clock Adjustment
1 Select Clock Adjustment mode
Press the [FM] or [AM] button.
Select the "Clock ADJ" display.
2 Enter Clock Adjust mode
Press the [4] or [¢] button for at least 1
second.
The clock display blinks.
3 Adjust the hours
Adjust the minutes
Press the [4] or [¢] button.
4 Exit Clock adjustment mode
Press the [MENU] button.
