20 Most Recent Kenwood XD-A55 CD Shelf System Questions & Answers
0answers
0answers
Manual de manejo
http://manual.kenwood.com/files/B60-5007-00.pdf here you have the link for tha manual
12/29/2013 1:09:37 AM • Kenwood XD-A55... • Answered on Dec 29, 2013
I put in the wires into the stereo for the
smps primary section ok secondary failure
7/31/2013 8:27:03 PM • Kenwood XD-A55... • Answered on Jul 31, 2013
0answers
2answers
Users manuals
Here is the manual for free(downloadable)
CLICK HERE
Feel free to leave a Fixya rating if this helped, and thank you for stopping by Fixya!
12/12/2012 8:54:55 AM • Kenwood XD-A55... • Answered on Dec 12, 2012
4answers
JVC turntable--broken motor?
I just worked on a unit with the same problem. The spindle bearing will seize up if it is not oiled at least once a year. Take off the feet and split the top and bottom. Remove the three screws that hold on the spindle. Remove the E clip that holds on the gear. Put it in a vise and press off the gear and remove the shaft. Thoroghly clean off the shaft and the bearing. Lub with 3 in 1 oil and reassemble.
7/14/2010 7:25:57 PM • Kenwood XD-A55... • Answered on Jul 14, 2010
I have an old kenwood shelf system, with the
Thanks for your concern. I was badly in need of a manual and luckily enough I got across a friend who had one in Uganda. So that solved my problem.
1/2/2010 2:40:54 PM • Kenwood XD-A55... • Answered on Jan 02, 2010
0answers
Er-cd11 code
Be the first to answer 10/21/2009 9:54:23 PM • Kenwood XD-A55... • Posted on Oct 21, 2009Be the first to answer
Kenwood XD-A55 CD player shows 'no disc'
The first thing you got to do is clean the laser lens maybe is dirt,witha qtip wet with alcohol clean the lens then with the dry part clean the residues of alcohol good luck
6/2/2009 4:00:40 PM • Kenwood XD-A55... • Answered on Jun 02, 2009
Toshiba SD-3980 DVD player not working
check and clean dvd lens. change lens if same problem.
6/2/2009 3:30:14 PM • Kenwood XD-A55... • Answered on Jun 02, 2009
0answers
Kenwood surround sound receiver krf-7050d stuck on mute
Check the Remote Control: Ensure that the remote control is functioning correctly. Press the MUTE button on the remote control to unmute the sound. The "MUTE" indicator should turn off. Manual Adjustment: Navigate to the receiver's setup menu and locate the audio settings section. Adjust parameters such as bass, treble, balance, and surround sound modes to achieve your desired audio quality. Physical Connections: Verify that all audio cables are securely connected to the appropriate inputs and outputs. Check if any cables are damaged or loose. Speaker Configuration: Make sure your speakers are correctly configured. If they are set to "Mute", unmute them. Factory Reset: Refer to the instruction manual for instructions on performing a factory reset.
4/3/2024 3:18:34 AM • Kenwood Audio... • Answered on Apr 03, 2024
I have a kenwood ka-129 which is currently muted
No, you must press mute again on the remote to toggle off mute.
3/31/2024 9:08:56 PM • Kenwood Audio... • Answered on Mar 31, 2024
Need to know how to disable remote function for a Kenwood stereo integrated amplifier ka-129
You could put a peice of gaffa tape over the sensor window if you do not read schematics very well.
3/31/2024 9:07:55 PM • Kenwood Audio... • Answered on Mar 31, 2024
How do I change the input from analog to digital or optical on my Kenwood Kraft-v7772d? Thanks
To switch the input on your Kenwood KRF-V7772D receiver from analog to digital or optical, follow these steps: Check the Manual: First, consult the user manual for detailed instructions specific to your model. If you don't have the manual, you can find it online. The manual provides step-by-step guidance on how to change inputs. Input Selector Button: On the front panel of your receiver, look for the Input Selector button. It might be labeled as "Input," "Source," or something similar. Press this button to cycle through the available input sources. On-Screen Menu: Some receivers allow you to change inputs using an on-screen menu. If your Kenwood receiver has this feature, navigate to the menu using your remote control. Look for an option related to input selection or source. Remote Control: Use your remote control to directly select the desired input. Look for buttons labeled with input sources (e.g., "DVD," "CD," "TV," "Optical," etc.). Press the appropriate button to switch to the desired input. Digital Inputs: If you want to switch to a digital input (such as optical or coaxial), ensure that your digital audio source (e.g., Blu-ray player, game console, etc.) is connected to the corresponding input on the back of the receiver. For optical input, connect the optical cable to the "Optical In" port. Analog Inputs: If you prefer an analog input, connect your analog audio source (e.g., turntable, cassette player, etc.) to the appropriate analog input on the back of the receiver. Remember to adjust the settings on your connected devices (e.g., TV, Blu-ray player) to output audio through the selected input on the Kenwood receiver. If you encounter any issues, refer to the service manual for further troubleshooting
3/31/2024 6:30:55 PM • Kenwood Audio... • Answered on Mar 31, 2024
My kenwood excelon DPX594BT audio suddenly cut out, why?
Check Speaker Wiring: Ensure that the speaker wires are properly connected to the stereo unit. Loose or damaged wiring can cause sound interruptions. Inspect the connections at both ends (stereo unit and speakers) to make sure they are secure. Bluetooth Pairing Data: Since you've already reset the car stereo and deleted all devices, let's focus on Bluetooth. Go to the Settings menu on your Kenwood system. Select Bluetooth and look for the option to Clear All Paired Devices. This will remove any existing Bluetooth pairings. After clearing the paired devices, try reconnecting your phone or other Bluetooth devices to see if the sound returns. Device Reset: Sometimes a simple reset can help. Turn off the car stereo completely and disconnect the power source (e.g., by removing the car battery cable). Wait for a few minutes, then reconnect the power and turn the stereo back on. Check if the sound is restored. Firmware Update: Visit the Kenwood website and check if there are any firmware updates available for your model. If updates are available, follow the instructions to install them. Sometimes software updates can address audio-related issues. Blue TI Light Flashing: The flashing blue TI light over BT1 indicates that the stereo is trying to establish a Bluetooth connection. Make sure your phone or other Bluetooth devices are discoverable and within range. Try pairing your phone again and see if the sound works. Manual Reference: For more detailed troubleshooting steps, refer to the Kenwood Excelon DPX594BT user manual. The manual provides information on settings, troubleshooting, and common issues. Remember that car stereo issues can be caused by various factors, including wiring, software glitches, or hardware problems. If none of the above steps resolve the issue, consider seeking professional assistance or contacting Kenwood customer support.
3/31/2024 6:26:43 PM • Kenwood Audio... • Answered on Mar 31, 2024
Kenwood XD-A55 CD Shelf System Logo
Popular Tags
27 questions posted
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Kenwood Audio Players & Recorders
Most Popular Question
jvc turntable broken motor
  • Audio Players & Recorders
