20 Most Recent
Memorex MT1701 17 in. HD-Ready LCD Television Questions & Answers
How to reset to factory settings
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
You have to enter its service mode to make it to Factory Reset. Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
IS the Mt1701 digital TV? If yes, why am I not
Yes it's a digital TV and off course this TV was getting signals, you need to scan the antenna Chanel through the scan option in your TV. try this first and let me know if this works.....
Good Luck!!
Thanks
Memorex 1080i hdtv model# mltd3222
I work for Memorex tech support. Our number is 800-919-3647.
I
know this isn't what you want to hear, but the problem you've described
can't be fixed with troubleshooting. Your TV will have to be repaired.
There is a part that has developed a defect and needs to be replaced. If
you're still in warranty, the TV will be repaired at no charge to you.
The warranty is one year from the date of
purchase. If you purchased an extended service
plan they will repair the TV at no charge as well.
If
the TV is no longer in warranty, it will likely cost a minimum of $150
parts and labor. This is assuming that you only need one circuit board or small part. If the problem is more than one of the circuit boards, the price of
repair could go much higher.
I hope I've provided you useful assistance and that this information
allows you to make an informed decision as to how to proceed from here.
Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Lost power Cord to T.V., All I have is a monitor. Need plugs
Try ordering a replacement from memorex through there web site, or any major electronics store might have a universal cord that could work with your tv. Be prepared to pay , alot. $80 -$120 . I had to replace my power cord for my panasonic lcd tv. cost was $110
Memorex MT 1701 Screen Problem
ok for those of you having the problem with the memorex mt1701 lcd tv / pc monitor well i had got one of a site call cl anyway when i first turn on it would stay on then turn off all i could here was the sound ok well i figuerd for sume reason the pc mode is the only way to get it to work right!! dont ask me y? but heres how to keep it on and able to watch tv. ok first when you turn the tv on it will go blank after a few when it does on your remote turn it to pc mode that will b the next one after tv you won be able to see if its in pc mode unless you turn the tv on and off a few time but you dont need to do that cuz pc mode is right after tv mode ok so your in pc mode you still wont see anything but what you want to watch for is the the power light it will remaine green for a few seconds than change orange when it does turn off tv than power on in pc mode you will see a no signal sign blinking swithch to the next mode quikly before the light goes orange again after this youll be able to watch tv but keep in mind iv had to youse this methode every once in awile. sumtimes whe id turn the tv of and on it would go to the blank screen again and sumtimes not so i hope i helped sum of you with this problem but thats the way this tv works for sum reason if you have any questions feel free to ask thanks and i hope this help you!!!!!!!!!
FUZZY (SNOWY) PICTURE
Well, I can tell you it shouldnt have anything to do with your not having an HD box. The TV does not require a HD signal to give you a quality picture. The HD box only gives you the enhanced HD signal, but should work as any regular TV without it. How do you have it connected?
My memorex hdmi mirror for android isn't putting out wifi signal
It seems like the Wi-Fi module on your Memorex HDMI Mirror may be faulty or malfunctioning, preventing it from broadcasting a Wi-Fi signal. Here are a few troubleshooting steps you can try:
Make sure your Memorex HDMI Mirror is within range of your Wi-Fi router. Move it closer to see if it picks up the signal.
Reset the Wi-Fi module by pressing and holding the reset button on the device for at least 10 seconds. Make sure the device is not connected to the TV while doing this.
Try connecting the Memorex HDMI Mirror to a different HDMI port on your TV to see if that resolves the issue.
Check if there are any firmware updates available for the device. If there are, update the firmware and try again.
If none of the above steps work, you may need to contact Memorex customer support or take the device to a repair shop to have it checked for any hardware issues.
2/24/2023 2:32:24 PM •
Memorex...
Answered
on Feb 24, 2023
How do I power on my Memorex HDMI screen mirroring device
- Make sure the device is properly plugged into a functioning HDMI port on your TV.
- Check the power cord for the device to make sure it is properly plugged into a functioning outlet.
- Check the TV's settings to ensure that the correct HDMI input is selected.
- Press the power button on the device to turn it on. If the device has a separate power switch, make sure it is in the "On" position.
1/3/2023 11:31:16 PM •
Memorex...
Answered
on Jan 03, 2023
My memorex hdmi mirror for android isn't working
Once memorex is connected to your tv and you've provided the correct username and password for your hotspot, then everything should work at least at some pace.
Please keep in mind that any type of streaming over mobile data maybe limited based on your mobile plan.
Whereas if you use, home or office based wifi, the streaming should be more fluid.
If still having an issue, please unplug and then plug back your memorex device before trying to connect to wifi again.
Thank you.
10/15/2022 9:37:43 PM •
Memorex...
Answered
on Oct 15, 2022
