20 Most Recent
Memorex MVD2022 DVD Player Questions & Answers
I have a memorex mvd2040 no power
I have a Memorex MVD2023 DVD Player which I've had less than a year, and have the same problem - suddenly no power. The Standby/Power On indicator light is off. Any solution or just buy a new machine?
Memorex dvd player pscan split screen
Memorex MVD2042 - The only switch on the back of the unit had gotten bumped when something fell behind the unit, thus causing the same issue mentioned here. Looking at the front of the unit, the switch is straight back from the disc tray on the left. (of course, if you're looking at the back, it's on the right side) This switch is for "Progressive Scan" either "on" or "off"
Thanks,
Wizard_Yo
Disc tray does not open
When you press the eject button you should hear the loading motor engage trying to open the dvd door, if you hear the motor! it indicates a bad loading belt that is stretched or direct drive gear problem, either way dis-assembly will be required to take a shot at repair.
I have a dish network
We would be happy to help you with getting your DISH Networkremote to control your DVD player. Start by holding down the TV button located on the top of your remote until all mode buttons come on, then release. Use the number buttons to enter thecodes for your Memorex MVD2022 DVD Player; here some of the codes we currently have: 549, 554, 566, 789, 516, and 533.Press the pound (#) button after code has been entered. To check that the code works try several differentfunctions on the remote to make sure it will properly operate the DVD player. Keep inmind that some codes may not be compatible with your equipment. If this is thecase, please try the other codes listed for that device until you find one thatis compatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Memorex burner tray on computer will not open
There should be a small hole on the right side bottom of the tray.....take a paper clip and insert it in the hole....while pushing the eject button...it should open then.....let me know if i helped you.
