20 Most Recent NAD 218THX 2-Channel Amplifier Questions & Answers
How do I connect my
hi,
For connecting these to your amplifier you need 4 Stereo RCA Cable.
1.Connection for cd:
Take one of the RCA cable connect the one end (red/white) jack to the line out of your cd and connect the other end (red/white) to the CD input of Your amplifier.
2. Connecting the tunner:
Take one of the RCA cable and connect the one end (red/white) jack to the line output of you Tuner and connect the other end (red/white) to the TUNER input of your amplifier.
3. Connectiong the tape deck:
Now you have two RCA cable. Take one of the RCA cable and connect the one end (red/white) jacks to the PLAY out of the Tape deck and connect the other end (red/white) to the TAPE 1 play input of your amplifier.
Now connect the last RCA cable. Connect the one end (red/white) jack to the record input of the TAPE deck And connect the other end (red/white) to the TAPE 1 Record input of your amplifier.(this connection will help you to record to tape from cd or tuner. if you are not interested in recording then you can avoid this connection.)
Now you can select these three items from the frond plannel control switch of the amplifier.
ok
7/28/2011 1:05:25 PM • NAD 218THX... • Answered on Jul 28, 2011
Hi my amp left channel does not work. the speaker
It could be a number of things. Try this test first though. Play some music and swing the balance control to the bad channel and turn up the volume all the way if needs be. If you hear any music breaking in the pre-amp is ok. If not it could be dead. Again if you hear faint music it's the power amp that's not working.
Next have a look inside. You should be able to identify the channels by following the wires from the speakers. Remember that stereo amps are just two mono amps joined. So the Right Channel will act as a guide to what the left should look like. Plus if you are any good with a volt meter provide the correct voltage indications. Any burnt/damaged parts on the left and not on the right is an indication of the fault area. If you have no output from the above test pay close attention to those parts on the heat-sink for the affected channel.
Ignore the power supply parts are anything that is on it's own, unless it's an IC with both channels going into it. As they can go faulty on one channel, but not the other sometimes.
If you can't find anything it might be an idea to replace the left output device(s).
5/25/2011 3:59:40 PM • NAD 218THX... • Answered on May 25, 2011
NAD S200 one channel is not working
You have a fault in the power amp. Identify the faulty channel by following the input leads. As, a stereo amp is basically two mono amps put together. You can compare the bad channel with the good one. First thing to do is a visual look around. If you see something odd looking in one channel and it's the faulty one, compared with the good channel, you might have found the cause. Look at the devices or device on the heatsink especially. If nothing stands out, the next thing to do is test the channels. You can do this in two ways. First, by touching the parts on each channel (with power on) with an insulated screwdriver. If you get a buzz in one channel and nothing in the bad one, in the same places of course! You might have located the faulty device. You can do the same with a volt meter. The readings should be the same in each channel. Work forward from the end of the preamp stage. Don't bother with the power supply parts, as they are common to both channels. By the way, don't short anything!
2/25/2024 7:26:01 PM • NAD Audio... • Answered on Feb 25, 2024
I have a Nad Receiver T748 , I can not connect any device with HDMI at port 2, 3, 4, only port HDMI 1 is working.What should I do
I have nad t748 but not switching on the power on tha auto turn off
7/23/2023 4:01:40 AM • NAD Audio... • Answered on Jul 23, 2023
I have a NAD 1600 receiver for 40 years. It always worked fine!! I just moved it 15 feet to new room and volume seems stuck on high! Knob turns but volume doesn't change. What happened??
It is funny, I was just reading an article today about New Acoustic Dimension Cassette decks saying they were top of the line and equal to Nakamichi. The most likely reason is that the volume control needs cleaning with Electrical Switch Cleaner. You would have to remove the case and look. It is worth a quick spray. This says it has a motorized volume control. https://www.google.com/search?q=nad+1600+receiver+volume+on+high+volume ..
2/24/2023 3:31:57 AM • NAD Audio... • Answered on Feb 24, 2023
Where can I get a volume and balance control for a 1990 or so NAD 1300 preamp?
You can find volume and balance control components for the NAD 1300 preamp from a variety of sources. You can check with NAD directly, or look for parts on websites such as eBay or Amazon. Additionally, you may be able to find parts from audio/electronics shops in your local area.
2/4/2023 5:23:08 AM • NAD Audio... • Answered on Feb 04, 2023
Have a Nad 3020 using as preamp to Nad 2600 amp. Is there a way to hook up an equalizer
NAD (New Acoustic Dimension) was all the rage when I was into composite audio in the 1970s. Not sure why would want to tweak that sweet clear natural sound like the performers played it. Your problem will be that you are loading an amp to a pre amp. https://www.google.com/search?q=Nad+2600 https://www.google.com/search?q=Nad+3020 https://www.google.com/search?q=nad+3020+nad+2600+graphic+equalizer ..
3/5/2022 5:41:13 AM • NAD Audio... • Answered on Mar 05, 2022
Nad 326bee popping sound?
Does it occur on both channels at the same time, (power supply) or independant channels, (coupling capacitor).
2/18/2022 5:59:47 AM • NAD Audio... • Answered on Feb 18, 2022
NAD 5425 CD Player display light out
Hi aartman
Yes it does have backlamps.
They are soldered to the PCB so you will need a few tools like a soldering iron, philips screwdrivers, solder, and some replacement lamps. Replace the lamps with this type from Farnell electronics. They have a 15000 hr life expectancy and last alot longer in the unit. I have tried many types of lamps over the years, and found these are the best choice if you want them to last.
FOR YOUR SAFETY-BE SURE TO DISCONNECT FROM THE MAINS BEFORE REMOVING THE LID
To get access to the lamps, you need to pull the main PCB out of the chassis to then get access to the bottom side of the printed circuit board where the 2 screws that retain the white lamp reflector assembly. Change both lamps with the type I mentioned,
6ab9edb.jpg Be careful not to flex the LCD display that is now exposed, it is quite fragile with the support of the lamp reflector cover no longer in place. ... reverse procedure to reassemble and away you go.
I am more than happy to talk about this solution with you further. Just ask away. Cheers
regards
robotek
10/3/2021 4:04:40 PM • NAD Audio... • Answered on Oct 03, 2021
3answers
Nad t753 volume control knob doesnt work
I'm going to assume that you mean it jumps around, volume up/down by itself? If so, you have a bad rotary encoder. If you are interested in having your NAD repaired, please visit my website at audioserviceclinic.com. You may contact me there. Thank you.
9/13/2021 12:24:27 AM • NAD Audio... • Answered on Sep 13, 2021
4answers
How to reset a NAD L54 DVD reciever?
This is the technical solution, you have to open the unit:Locate IC33 and connect pin 6 to ground, connect power, and then remove the ground connection at pin 6.The unit will then boot up in factory default.Henrik Pedersen
4/13/2021 5:28:32 AM • NAD Audio... • Answered on Apr 13, 2021
My NAD T750 will not power up unless I tilt it on its edge. Then all controls are working.
Bad connections along the front PCB.
2/7/2021 4:36:36 PM • NAD Audio... • Answered on Feb 07, 2021
NAD T163 LCD display going in and out
Check your connections to the plug there will be a little spark. repair it
6/20/2020 6:04:38 AM • NAD Audio... • Answered on Jun 20, 2020
Preamp/Processor missing menus/options for DTS
Solved the recognition of DTS signal issue but the DTS options/settings in the menus are still not appearing - believe the previous owner may have upgraded the software. The solution for the DTS signal recognition was an output setting on the DVD (blu-ray) player - digital output vs analog.
2/21/2020 7:30:31 AM • NAD Audio... • Answered on Feb 21, 2020
NAD C542 does not turn on. How to fix it?
Hi Michael, check inside your NAD C542, there are 4 fuses, check that none is open, if all are well, you could have problems with the capacitors in the area of the power supply or in the case of the Transformer If you do not have technical capabilities to evaluate the above, consult a specialized technical service I hope you can solve the problem Greetings Franco Dosil http://diagramas.diagramasde.com/audio/NAD-C542-Service-Manual-Schematics.pdf Hola Michael, revisa en el interior de tu NAD C542, hay 4 fusibles, controla que ninguno se encuentre abierto, si est?n todos bien, podr?as tener problemas con los capacitores del ?rea de la fuente de alimentaci?n o en el pero de los casos el Transformador Si no tienes capacidades t?cnicas para evaluar lo previamente indicado, consulta un servicio t?cnico especializada Espero puedas resolver el problema Saludos Franco Dosil
9/16/2019 6:16:23 PM • NAD Audio... • Answered on Sep 16, 2019
My NAD C542 CD player does not turn on. What can the problem be and is there a fix?
Hi Michael, check inside your NAD C542, there are 4 fuses, check that none is open, if all are well, you could have problems with the capacitors in the area of the power supply or in the case of the Transformer If you do not have technical capabilities to evaluate the above, consult a specialized technical service I hope you can solve the problem Greetings Franco Dosil Hola Michael, revisa en el interior de tu NAD C542, hay 4 fusibles, controla que ninguno se encuentre abierto, si est?n todos bien, podr?as tener problemas con los capacitores del ?rea de la fuente de alimentaci?n o en el pero de los casos el Transformador Si no tienes capacidades t?cnicas para evaluar lo previamente indicado, consulta un servicio t?cnico especializada Espero puedas resolver el problema Saludos Franco Dosil http://diagramas.diagramasde.com/audio/NAD-C542-Service-Manual-Schematics.pdf
9/16/2019 6:12:05 PM • NAD Audio... • Answered on Sep 16, 2019
NAD 218THX 2-Channel Amplifier Logo
4 questions posted
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Steve Sweetleaf
Steve Sweetleaf
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • NAD Audio Players & Recorders
Most Popular Question
connect
  • Audio Players & Recorders
