20 Most Recent Evga e-GeForce 6200 GeForce 6200, (256 MB) Graphic Card Questions & Answers
Installed new geforce 6200 pci graphics,onboard graphics out,no graphics
Go to control panel then device manager then eliminate the drivers for your old card and the new one as well restart computer. Run the driver install if prompted to do so. Hope this helps
1/12/2014 5:26:06 AM • Evga e-GeForce... • Answered on Jan 12, 2014
Want 1400x1050 resolution
It depends on the monitor too, and the refresh rates it can support.. But it seems to me that 256 MB is rather skimpy. Try changing the resolution to 1200x800 first. If the monitor or screen can handle it and it remains stable and no hangups in games or other demanding programs then try to change to some other higher resolution. Before you make any hazardous step backup your computer or set a restore point. In case of trouble you will be able to load the last configuration that worked. Good Luck.
12/23/2013 3:41:18 PM • Evga e-GeForce... • Answered on Dec 23, 2013
Download e-Geoforce N6200, 256MB DDR2
Hello the driver can be downloaded here:http://www.nvidia.com/Download/index.aspx?lang=en-usBy selecting the graphic card model, and your windows system.Or use Automatically find drivers for my NVIDIA products, by installing a small bit of software.Good luck
3/16/2013 3:33:17 PM • Evga e-GeForce... • Answered on Mar 16, 2013
2answers
EVGA GeForce 6200 512 MB card + mouse pointer
sounds like yo had the same Problems that I had with my 5200 geforce The install did not go well. what was happening was the direct x was binding to the old mother board graphics system and not the new card . to make it rebind just change the refresh rate in the nvidia icon in your task bar . disable the display adapter from device manager for the motherboard graphics .put the card in the slot change the monitor cord boot up check you direct x by typing in run dxdiag and test directx to be sure it is running with your card you can also see that from the about nvidia you must have the driver for the card installed to do all this.. hope I helped install the driver first then disable download latest drivers here http://www.nvidia.com/Download/index5.aspx?lang=en-us
3/30/2012 4:17:59 PM • Evga e-GeForce... • Answered on Mar 30, 2012
I have a new geforce
I am presuming that the mainboard is an Asus model with integrated VGA.
In order to perform the following steps you may have to remove your new VGA board and reconnect your monitor to the mainboard VGA in order to have a display on your monitor.
If your new VGA board is an AGP or PCI express, connecting your monitor to the new VGA board should have been detected and applied the VGA output through the new board. If the new VGA board is a PCI type then go to the new steps to make changes to your CMOS via the BIOS settings.
If not the Asus mainboard may have to have the CMOS setup change through your BIOS settings.
Upon bootup you should be able to hit the delte key and the BIOS screen should come one.
Scroll down to the a view that will show "Onboard Settings" or similar wording.
Select and disable the Asus onboard VGA or video.
If problem still persist, then go to the Assus.Com web site for support on your model Asus mainboard for the maunual, or trouble shooting questions on settings.
Good Luck
9/5/2011 1:52:39 PM • Evga e-GeForce... • Answered on Sep 05, 2011
I installed my card in
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them they could be faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question? mark or exclamation mark ! or a red x right click select reinstall drivers also you might uninstall the display adapter restart your computer then reinstall the display adapter and its drivers this would apply to the sound video and game controllers to
If your computer came with a motherboard disc the drivers could be on it
hope this helps
4/19/2011 12:57:14 AM • Evga e-GeForce... • Answered on Apr 19, 2011
I would start world of
Trystrom -
It's possible that your video card is overheating, or broken. This can sometimes be fixed, but not always. If you are willing to spend a few dollars at a local computer/office supply store for a can of pressurized air, you can open your computer and use the pressurized air to forcefully blow all of the dust out of the video card cooling fan. Dust buildup frequently causes overheating in older cards, like you GeForce 6200.
Also, you will want to use the real canned air product. A vacuum seems like it would work, but creates dangerous static electricity that can fry the fragile electrical systems in your computer.
3/3/2011 10:15:54 PM • Evga e-GeForce... • Answered on Mar 03, 2011
I installed a e-geforce 6200 256 as a second video
Check if the power supply can handle the power needs of that card in addition to the hardware it already powers.
8/31/2010 7:45:50 PM • Evga e-GeForce... • Answered on Aug 31, 2010
I have an EVGA 6200 in an HP P4HT...it is working
you have an nvidia based card. there should be nvidia control panel with those drivers, if not download it. to find out just right click an empty portion of your desktop. then look for nvidia control panel. if it is there just start it. then on the left side of the control panel look for display and click the subcategory set up multiple displays. this will give you a window that shows both of your displays. just uncheck the clone displays. this will allow you to configure them independently.
6/27/2010 12:02:28 PM • Evga e-GeForce... • Answered on Jun 27, 2010
How do i install geforce 6200
Hello! You must first shutdown your computer. Open your cpu and connect the video card on the agp slot of the motherboard. Make sure it is properly seated. Return back the cover of the casing. Connect the vga cable of your monitor to the vga connector of the video card. turn on the computer. The operating system will automatic read the new found hardware. Now try to download the driver of the video card this will give the video card its properties to change its resolution sizes and graphics output. The download site can be found here, just enter the code you see from the image and click download.
6/12/2010 5:36:53 PM • Evga e-GeForce... • Answered on Jun 12, 2010
My driver cd not installing video drivers on
You can go to the evga website and download the windows 7 Drivers.And install them . the web site does have windows 7 drivers for that card.
5/16/2010 5:22:50 AM • Evga e-GeForce... • Answered on May 16, 2010
Hi, I have an EVGA GeForce 6200 AGP, 256MB DDR2
This is a common problem, you need to clear the CMOS which will also reset the BIOS settings. Here's a few ways you can do that:
http://pcsupport.about.com/od/fixtheproblem/tp/clearcmos.htm
3/8/2010 12:21:40 AM • Evga e-GeForce... • Answered on Mar 08, 2010
I lost the installation cd?
You can download the software you need here: http://www.evga.com/support/drivers/
2/7/2010 3:14:44 AM • Evga e-GeForce... • Answered on Feb 07, 2010
Scrolling delays, choppy scrolling as if multiple pages
Did you install the original drivers from the vendor of the e-Geforce card if not try doing it it should fix the problem.
If you dont have it download it from here
Also try to update the directx
12/1/2009 3:34:21 PM • Evga e-GeForce... • Answered on Dec 01, 2009
How can I get the digital port working? The VGA
go to nearest delear for your requirement
10/2/2009 12:22:56 PM • Evga e-GeForce... • Answered on Oct 02, 2009
After card install, images in window are tiny. Have adj scn res but too big or too small. Help!
I think you need to install the nvidia drivesr for the video card, you can get them from www.nvidia.com its the first link, Download Drivers on the page.
Thanks,
Ekse
6/3/2009 1:54:15 PM • Evga e-GeForce... • Answered on Jun 03, 2009
EVGA e-GeForce 6200
http://www.evga.com/support/drivers/default.asp?switch=2
Try downloading and installing this one
5/28/2009 11:34:00 AM • Evga e-GeForce... • Answered on May 28, 2009
Monitor goes black after windows boots up
this is probably your screen refresh rate is too high.try booting the computer in vga mode and lower your default screen refresh rate.if it fails try with a older driver. the problem might be due to overheating. try cleaning your cabinet and install a new heatsink and apply new thermal paste on your vram chips.
3/23/2009 8:41:36 AM • Evga e-GeForce... • Answered on Mar 23, 2009
Black screen freezing and rebooting
i think you lost it, coz i have the same prob, then i have to replace it after every try to fix it (like re-nstalling driver even windows too).
3/4/2009 7:55:32 PM • Evga e-GeForce... • Answered on Mar 04, 2009
Evga e-GeForce 6200 GeForce 6200, (256 MB) Graphic Card Logo
39 questions posted
Top Evga Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you an Evga Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Evga Computers & Internet
Most Popular Question
  • Computers & Internet
