20 Most Recent
Sony (VPCEB11FM) Notebook Questions & Answers
MY LAPTOP IS OVERHEATING WHAT SHOULD BE DONE?
Most likely yout exhaust fan is clogged with dust and lint. You didn't give a model number but some fans are easier to acces than others. Some require disassembly. Excessive heat will ruin your motherboard eventually. If you are not comfortable taking it apart you can try to blow compressed air back throught the exhaust vent for a temp. fix. If you do that stick a paper clip or something else in between the fan vent and fan blades to prevent the fan from spinning when blowing it out. ( a spinning fan will produce an electrical current back through the motherboard connection which you don't want ).
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
