20 Most Recent
HEWLETT-PACKARD Compaq Presario CQ60-615DX Notebook Questions & Answers
My screen gets a black box in the middle of it for a few seconds and goes away
whoo hooooh a full model number but no OS stated
CQ60-615DX
i guess all users of PC are clueless what the OS is or its name.
vista or w7? (click control panel then system , bingo OS) name)
no photos posted of this black screen box. nor when it happens.?
I see HP dropped all software support now, but yes some guides still there. 2008? year? LT?
so HP does drop support in10 years, they even say that.
the BUG battery main is long ago bad and shorted, keep the battery out for ever, or buy a new one. end big battery facts,
keep it out.
now run on AC ? power ok, only (wall power!)
then get a new coin cell battery HP RTC stated in the service manual . the manual to do that is missing now.
HP is trimming off line books on this pc.as we type.
2008 is the worst year for any laptop, the solder ball years from hell.
but if the PC runs ok mostly (you never once said tHAT)
The its not bad nvida chip inside. (causes full black screens or lines)
but these guys to. see page 4-12 actual = RTC coin
page 51 in PDF. covers the coin cell swap out.
$2 part for sure bad at 10years old 7 is par.
this book was deleted at HP, (bums)
https://www.manualslib.com/manual/71703/Hp-Cq60-Series.html
Will chromecast work with compaq cq60-615dx
Chromecast is connected to the TV and not to your computer. Your TV should have free HDMI port to connect the Chromecast.
You should WiFi configured and both chromecast and you computer ( you can use wired connection for PC) should be connected to the same network (router).
My computer shut off out of nowhere with no warning.
CQ60-615DX shutdown do follow step:
1) as a new laotop with windows 8 return to windoes 7 need to update a proper BIOS version to get good campatible current system
2) the Battery should be good, the charging issue is also link to BIOS version support, or check dc jack LED indicator on when adapter plug in. not lights no charging
3) check adapter plug in DC jack lights, shutdown could be related to if the lights not on. may be try change adapter first
3)
My compaq presario powers off suddenly even if it is conected to AC
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail. A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust. Check the CPU fan to see if it spins freely, if not replace the fan. If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
My Cq60 Compaq laptop doesn't turn on.
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact. Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
Presario cq60 missing dvd drivers
Does the Windows Installation complete and have you tried skipping when it asks for them? Also make sure your install disc hasn't got a big thumb print or scratch on it.
Cant play sound through headphones
Sound driver might be missing check in device manager you might be getting a yellow question mark icon try to install sound driver as well as check the settings in the sound icon it might be muted.
Cq60-615dx power problem
When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous. Maybe your power cord is bad if you don't get anything to happen whatsoeverwhen you press the power button. And if that's true maybe you wasoperating off the battery the last time you had it on and since the power cordis bad, it was not charging the battery so the battery is drained and the powercord is bad.Maybe you have a Static Charge Buildup. Remove the Power Cord, Remove theBattery, then Press and Hold the power button for 30seconds. After 30 seconds plug the power cord back in (leave the batteryout) and hit the power button to see if it boots. If it does, you can putthe battery back in and let it charge.
