20 Most Recent Panasonic CT-27SL14 27" TV Questions & Answers
Tv clicks on then off on its own
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
7/30/2015 5:51:27 AM • Panasonic... • Answered on Jul 30, 2015
Problem with panasonic ct27g5b, flyback transformer secondary volts too high changed str58041 but power supply only make whining sound when turned on
Check all the components in the main power supply board, including STR switching device, for any damage, or loose solder terminals. Check and replace the damaged component. Check the horizontal output transistor too, for short. Check it for collector to emitter, or collector to base short. It will be best to replace it with a new one, and check. For more information go to http://electronicshelponline.blogspot.com/
12/11/2013 6:48:08 AM • Panasonic... • Answered on Dec 11, 2013
No sound on Samsung DLP TV. I have a Samsung DLP
If you've plugged in a headphone socket to to it, pull it out.
8/27/2013 6:17:58 PM • Panasonic... • Answered on Aug 27, 2013
Universal remote code
0171 0148 0054 0170 0062 0374 0381 0437 0950 0003 0070. These are the setup codes to check. To get more, visit this site.
2/2/2013 2:46:16 PM • Panasonic... • Answered on Feb 02, 2013
The original remote does not work, allthe lights blink when you program, but does not turn on
The II2C bus inside the TV [circuit] does not respond to remote signals. Your TV need a thorough checkup. Actually this is a skilled work and not a user repairable one. Contact any experienced service technician.
1/4/2013 2:44:28 PM • Panasonic... • Answered on Jan 04, 2013
No H/V dedlect, Audio is OK
Check and replace damaged component/s at it horizontal output stage circuit. It includes the Line Output Transformer.
10/13/2012 11:22:24 AM • Panasonic... • Answered on Oct 13, 2012
Panasonic service manuals-online
8/16/2012 6:37:10 AM • Panasonic... • Answered on Aug 16, 2012
Panasonic CT-27SL14 problem: There is band
horiz.output IC going bad,need to replace it
11/16/2011 4:55:01 AM • Panasonic... • Answered on Nov 16, 2011
White lines across top of screen
Need to replace vertical capacitor at vertical Ic.Leaky capacitor.
11/16/2011 4:51:41 AM • Panasonic... • Answered on Nov 16, 2011
Tuner appears to be stuck in channel 4. Cannot
It is a tuner selector problem, either the processor controller ic is the problem, or the selector ic. The easiest solution use a VCR as your channel changer, and check to make the VCR is set to channel 4.
1/3/2011 9:21:25 PM • Panasonic... • Answered on Jan 03, 2011
It appears that the image on the screen is zoomed
If the image on screen is zoomed both in vertical and horizontal direction, your TVs power regulator inside it is faulty. [Overvoltage]. If it is zoomed in vertical direction only, that is only the height of the picture is zoomed, you can adjust it with the remote control button directly on going through menu and get in to the function menu. Normally all TV remote has a special button marked as "Zoom" which on pressing it once the picture get zoomed, again another press the picture gets wide and again an another press picture will come to normal mode. You should select normal mode to retify the problem.
10/16/2010 2:14:39 PM • Panasonic... • Answered on Oct 16, 2010
The picture get black after giving it a push it
it would seem your fault would be a dry joint ( a solder point on the circuit board has come loose) the only way to fix this is to have the board taken out turned upside down and find were the dry joint is and re - solder it. if your not aware of electronics then it will have to go into the shop. a dry joint repair should only cost you around $ 40.00 - 60.00 in the mean time sticking a folded peace of cardboard under the tv might work as it puts preasure on the board pushing the solder point against the joint
good luck
7/13/2010 7:52:03 AM • Panasonic... • Answered on Jul 13, 2010
Picture curves in at the sides after switch on
That sounds like the convergence has gone bad. For help with this issue call our service manager at 3037706535 or click the link below
PANASONIC TV REPAIR AT AAAA TEVA
7/7/2010 6:52:17 PM • Panasonic... • Answered on Jul 07, 2010
No picture with sound
check the tail end of the picture tube do you see a light on it?that is the heater of the picture.without it your screen will be black. If there is no light from the heater there should be an open resistor connected to he heater replace them. .next check the screen adjustment of your plyback.screen adjustment is right in the body of the plyback there are 2 adjustment in there the upper is the focus adjustment and the lower is the screen adjustment turn it clockwise untill you reach the preferred adjustment.. tnx
please rate my help
6/5/2010 5:56:58 AM • Panasonic... • Answered on Jun 05, 2010
I get the picture but there isn't volume
back in the have a an audio switch, try push.
5/6/2010 6:20:04 PM • Panasonic... • Answered on May 06, 2010
27" panasonic tv, picture blinks and goes black frecuently.
cold solder in vertical ic
4/24/2010 7:30:58 PM • Panasonic... • Answered on Apr 24, 2010
Panasonic 51 inch rear projection--bought in 98 has dark picture
http://www.purelandsupply.com/Panasonic-Projector-Lamp.html or go here and call them @ https://www.interlight.biz/ they will answer any question and are half the price most of the time, please give me high rating
4/16/2010 9:42:48 AM • Panasonic... • Answered on Apr 16, 2010
My panasonic ct278sl14 shuts off almost
a cap in the power supply is not filtering the ripples properly check c507 in the power supply and surrounding caps.also replace Q401 HOT.good luck.if you are not a tech have a tech do the job for you.as there are no user friendly components inside a tv store voltage that are very high and can be fatal if you get shock.good luck.
2/28/2010 12:50:54 AM • Panasonic... • Answered on Feb 28, 2010
Panasonic CT-27SL14 27" TV Logo
38 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
original remote not work allthe lights
  • Televison & Video
