20 Most Recent
Panasonic TH-50PX50U 50 in. Plasma HDTV Questions & Answers
Flash code
It's a fail safe to save other board inside your set from stray voltage. The error LED code says your PSB Power Supply board has some blown capacitors on it. First try a hard reset by unplugging the set for 4-6 hours. If that doesn't work you need to remove the pack panel and look for the Blown caps on the PSB. Caps should be completely flat (X) top view. Not puffed or bulged. Radio shack harbor freight for a soldering kit with flux and some new thru-hole caps about 2v above your current cap rating. Get them too big and you risk them exploding and they are hard to seat.
5/13/2014 8:17:06 PM •
Panasonic...
Answered
on May 13, 2014
Power Failure
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "
Mosaic" will make surf easy.
Blinking codes details to many popular brand TVs are given.
Gopakumar Gopalan Google
3/2/2014 9:56:59 AM •
Panasonic...
Answered
on Mar 02, 2014
I have an aspire one laptop and a video convertor.
Are you connecting the svga out of the laptop to hdmi of tv via a converter? This set should have an svga input on it. try connecting this directly to svga on computer. Computers and converters and hdmi inputs on tvs are always a challenge. Newer laptops have hdmi outputs on them and are seem to work better.
1/8/2014 6:30:40 PM •
Panasonic...
Answered
on Jan 08, 2014
Your website does not work properly.
If you want a good website or any kind application then always acquire the services of Allerin. They use powerful Ruby on Rails technology to develop applications.
Allerin has many years of experience in application development and has completed many projects. For more information you can always visit http://www.allerin.com/
11/16/2013 7:15:24 AM •
Panasonic...
Answered
on Nov 16, 2013
Image does not fit screen.
Change the aspect ratio of the picture by entering the picture adjustment menu. Refer it user manual for more details.
5/29/2013 12:28:32 PM •
Panasonic...
Answered
on May 29, 2013
Fix sound card
To fix this problem is really a skilled work. After sound card replacement, you have to enter its service mode option to configure it. If
you wish to get more details, check this site linked below. Pull up older posts
there. Check the site with patience, as
it has over 2350 posts now. All are
related to electronic equipment repair help.
If you search the site in Timeslide option, which can be selected from
the drop down list at the top left of the display window, it will be easy to
locate the related post. You can also
do a search by type in the brand name
and model number to your device into its search box at the top right of display
window.
4/26/2013 4:57:26 PM •
Panasonic...
Answered
on Apr 26, 2013
