20 Most Recent Gateway Desktop / Intel Core i3 Processor / 8GB Memory / 1TB Hard Drive (DX484011E) Questions & Answers
With using, the computer without reason/ warning got stuck and I forced turn off the computer; then, tried to turn on again. It was not Boot. The power on, but it is stuck in there, no Boot. Help!
I think yiu also need to check your RAMs. Just use the one RAM and try by replacing and cleaning one by one. Thats only option you can check it.
5/17/2016 11:00:23 AM • Gateway Desktop... • Answered on May 17, 2016
Computer Crashes Error Code: Kernel-Power 41 (63)
The problem may still be your audio. If you go into the bios and switch the audio off and the problem disappears then you will need a separate audio card in a PCI slot.
2/13/2013 2:43:04 PM • Gateway Desktop... • Answered on Feb 13, 2013
Having problems upgrading my GatewayDX4840-11e to 32GB of memory.
Memory Type: DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900, DDR3 (non-ECC)Maximum Memory: 32GB Slots: 4Each memory slot can hold DDR3 PC3-10600, DDR3 PC3-12800, DDR3 PC3-8500, DDR3 PC3-14900 with a maximum of 16GB kit (8GBx2) per slot.**Not to exceed manufacturer supported memory.icon_note.gif
Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.icon_note.gif
How much memory your Windows OS will recognize depends on which version of Windows you are running. To utilize more memory, install a 64-bit version of your OS.
Thank You
TomMiller
Eng
8/24/2012 11:36:26 PM • Gateway Desktop... • Answered on Aug 24, 2012
What is the best way to keep these computers
Hello, I am the technician that you be assisting you today. My name is Norman-Wynne Damstra.Welcome to Fixya Jeffery.Yes you are quite correct, your upgraded computer system is giving off a large amount of heat, that graphics upgrade is quite substantial.See these off the shelf PC's from manufactures really don't take the computer gamer's needs into account with regards to cooling. Gaming gear gives off a whole bunch of heat and this heat as you have come to find needs to be expelled quite quickly for a stable and cool gaming computer system.Here are two possible solutions for this problem:Option 1.) Installing cooling into the side panel is the easiest, most effective way of cooling your computer's components. I would reccomend installing at least two 120mm fans. What you do is set the one so that the fans hub would sits directly above the CPU. This fan would therefore provide freash cool air from outside the chassis to your CPU cooler.The second fan would be installed so that the hub sits slightly below the Circuit Board (PCB) of the Graphics card. This fan would therefore provide freash cool air from outside the chassis to your Graphics card. Be sure to check that the fan, once installed over the Graphics card clears the actual graphics card once the side panel is slid closed.You will need to measure and drill 4 holes for each fan, and then cut out the metal in the middle for air to pass through the chassis side panel. One can buy 120mm fan grills to protect anything large from touching the fan blades, it also makes the mod look smart and finished off. They are bought in crome or black finish. Check your computer store.Now that the intake is sorted your will need to work on a suitable spot to install exhaust fans. Some-times there is enough space around the rear 80mm fan to drill and fit a 120mm fan. Again you will need to drill 4 holes and cut away the middle of the chassis for the air to pass through the chassis. You will need to check if this option is available to you. Another exhaust option is the top of the chassis for natural convection currents (hot air rising), usually install either 1 or 2 120mm fans depending on the position of the Power Supply, as some are fitted on the top and others on the bottom.Visit your local computer store for fan mounting; kits, ideas, available fan speeds and airflow rates, purchase fans.Option 2.) Involves the purchase of a suitable gaming computer chassis. These would be better suited to your gaming setup/needs and have lot's of fan install points. You would want to get one, if you so choose that offers 120mm or 140mm fan mounting options. Usually offering in excess of 3 mounting points. Giving your computer components freash air, thereby decreasing tempreature, increasing performance, reliability and longevity.There are lot of diffent sizes and styles available.I would reccomend either Cooler Master 690 series or Corsair.Take care!Norman-Wynne Damstra
11/20/2011 9:17:54 PM • Gateway Desktop... • Answered on Nov 20, 2011
My GATEWAY DX4840-11e did not power up, so I
CMOS Checksum Error, and having to set the Date/Time repeatedly, generally points to a bad CMOS battery.
If it were I, I would replace the battery with a new one. However this is what I would do.
Your computer is still under warranty. Opening the computer case may void the warranty.
Therefore you may not come to the same decision that I would.
On the motherboard is a round flat battery about the size of a U.S. Nickle.
It's a type of watch battery. Generally a CR2032.
Example;
http://en.wikipedia.org/wiki/CR2032_battery
A CMOS battery will generally last from 4 to 7 years. Perhaps the CMOS battery installed in your Gateway is bad. Just a lemon that came from the battery factory.
The battery holder on the motherboard is rounded in shape to fit the battery, and has a metal clip inside. There are different styles of fastening used in the clip design, but generally a small tab of the clip is eased to the outside edge of the battery holder, thereby releasing the battery.
This article will 'shed more light' on the various styles of CMOS battery holders,
http://www.hardwaresecrets.com/article/81
Proper procedure in order to replace the CMOS battery;
1) Unplug the computer from power.
[NOTE* Always unplug the power cord from the surge protector, and not from the computer's Power Supply. (Back of the computer) Unplugging from the Power Supply MAY cause a voltage spike. ]
2) Observe Anti-Static Precautions
Anti-Static Precautions:
Your body carries Static electricity.
Static will fry out (Short Circuit) the delicate hardware components inside a computer.
ALWAYS relieve your body of Static BEFORE working on a computer.
Computer unplugged from power, computer case open, TOUCH the metal frame of the open computer case.
This action will relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
3) Opening the computer case:
This is Gateway Support, and the Support Documents page for the Gateway DX4840 series of Desktop Computers,
http://support.gateway.com/us/en/s/desktop/2010/gateway/dx/dx4840/DX4840nv.shtml
I would like you to click on - Product Views.
Now click on Rear View.
Observing the rear of the computer look at the right side. Along the edge down towards the bottom is a screw. This screw is removed, then the Side Panel is pulled towards the rear of the computer.
(There is a raised portion, or hump, in the Side Panel for placing your fingers)
If your Gateway DX4840-11e desktop computer has an Asus M2N32-SLI Deluxe motherboard, the CMOS battery is located down towards the bottom of the motherboard, and slightly to the right.
For additional questions, or clarification to what I have stated, please post in a Comment.
Regards,
joecoolvette
5/8/2011 12:15:28 PM • Gateway Desktop... • Answered on May 08, 2011
Gateway dx4840-11e. During video can hear music
do you have the sound set to surrond sound? What it sounds like is that it is trying to play through surrond speakers but you dont have them, which is why you can hear the music and not the actors voices. click with the right mouse button on the speaker in the bottom right of your screen, then click on sounds , now click on the playback tab in the sound window, click on the sound device shown and then click configure, choose stereo and choose two speakers. Continue to the end then try to play the video and see if you can now hear the voices. If you cant then you maybe missing codecs needed to play the audio correctly. Please state if this is a movie you have downloaded or a dvd film on disc etc
4/2/2011 9:35:18 PM • Gateway Desktop... • Answered on Apr 02, 2011
I have the application SuperSU the free edition on my phone and everytime I try to use it to root my phone forwards me to an address on Chrome the simply says 502 bad gateway
you can use kingroot to root your phone. and some root apps might harm yor os i suggest you not to root your phone
3/1/2024 4:28:21 PM • Gateway... • Answered on Mar 01, 2024
I have a Gateway LP2417 monitor and there's No sound.Hoe do I fix it,so I can hear the video that is playing?
This monitor may not have built-in speakers. It may have supported Gateway's monitor mounted sound bar. That sound bar connected to the 3.5 mm audio out on a computer and a DIN port on the monitor. The simplest solution is to connect your source to appropriate speakers. Depending on your audio setup, you could connect the video source to a receiver with HDMI IN and HDMI Out (ARC), computer speakers or an audio extractor. (If you are using an HDMI cable between the Gateway LP2417 and a computer, you may need to reset the audio output to use basic computer speakers (3.5mm jack).) VGA and DVI connections don't support audio so I assume you are using the HDMI port. I hope this helps. Cindy Wells
1/18/2024 10:32:24 PM • Gateway... • Answered on Jan 18, 2024
I have a gateway Zx4931 and the power button is not working. Do I need to replace the power button or can I reconnect the wires?
Re connecting the wires may work without issues.
12/26/2023 5:46:39 PM • Gateway... • Answered on Dec 26, 2023
Do i need a driver for old gateway gmax2000 speakers connected to an old acer-based home built pc my nephew gave me?
No you don't need a driver. These are very plain powered speakers that come with a mains adapter and a lead with a 3.5mm stereo jack at both ends. Plug one in the speaker and the other into the headphone jack on the front or the speaker socket on the back which will either be a socket on the motherboard, or if your son put a sound card in the computer, it will be in a sound card. If it doesn't play straight away, go into Settings - Audio and make sure the sound card or the On-Board Audio is enabled. This shows the cable https://picclick.com/Vintage-Gateway-2000-ACS41-Altec-Lansing-Multimedia-Computer-314990339798.html#&gid=1&pid=1 More here https://www.google.com/search?q=gateway+gmax2000+speakers ..
11/29/2023 12:20:06 AM • Gateway... • Answered on Nov 29, 2023
WATTS REQUIRED FOR GATEWAY LAPTOP NV55C
110 watts for the power supply.
11/21/2023 1:16:48 AM • Gateway... • Answered on Nov 21, 2023
Wiring diagram for LX6200-01
10/30/2023 11:58:58 PM • Gateway... • Answered on Oct 30, 2023
How to make touch screen on gateway computer upside down and how to put it back?
f you want to use your touch screen on your gateway computer in an upside down orientation, there are a few things you need to do. First, you need to change the orientation of the screen in the control panel. To do this, go to the control panel and select "Display." Next, click on the "Settings" tab and then click on the "Orientation" drop-down menu. Select "Landscape (flipped)" from the menu and then click on the "Apply" button. Now that the orientation of the screen has been changed, you need to adjust the position of the touchscreen so that it is in the correct position. To do this, go to the control panel and select "Hardware and Sound." Next, select "Pen and Touch" and then click on the "Calibrate" button. Follow the on-screen instructions to calibrate the touchscreen. Once you have finished, the touchscreen should be working correctly in the upside down orientation. I hope this helps!
3/14/2023 5:41:18 PM • Gateway... • Answered on Mar 14, 2023
I have a Gateway Laptop that on startup only goes to the configuration screen. It won't boot Windows at all
They deleted the Operating System by deleting their own stuff Docs, images, Saved Links etc. and also everything in Windows System probably in spite. You need to reload the operating system (Win 11) from fresh. Charge them from their final pay check, or ask IT to do it.
3/1/2023 1:19:14 AM • Gateway... • Answered on Mar 01, 2023
2answers
Gateway / Packard Bell EASYNOTE MS2291 Laptop will not start.
Question edited for a lot more clarity, FULL 'make, model (what it is)'. Question moved from 'Power Computers'. Connect a computer monitor to the port on the back. When I Google the model number the first thing that shows is Replacement LCD Screens for it which leads me to believe there is an issue with them. There is three parts to the display, the video card section, the exciter module and the screen itself. It needs correct diagnosis, or buy a new one now you have reset it clean, if that is what you mean by 'hard restart'? You might mean 'hard boot', power off and back on without proper shutdown. That is bad for the OS. https://www.google.com/search?q=Model+MS2291 Keyboard shortcuts for shutdown
How to Shut Down or Sleep Windows 10/11 With a Keyboard ...
https://www.makeuseof.com > Windows 1. Use the Power User Menu Shortcut · Press U again to shut down Windows. · Hit the R key to restart. · Press S to put Windows to sleep. · Use H to hibernate. · Hit ... Sleep Mode Issues · ‎Establish a hotkey · ‎Guide to hibernation on.....
2/26/2023 8:34:30 PM • Gateway... • Answered on Feb 26, 2023
I have a 2017 Gateway All in One Pentium Model zx6980 Push power button monitor comes on faintly No signal HD something. Will not boot
It sounds like there could be a few different issues going on with your computer. Here are some steps you can try to troubleshoot the problem:
  1. Check the connections: Make sure all cables and connections are secure and properly plugged in. This includes the power cable, monitor cable, and any other peripheral cables.
  2. Check the monitor: Try connecting your computer to a different monitor to see if the issue is with the monitor itself. If the other monitor works, the problem is likely with your original monitor.
  3. Check the hard drive: Disconnect the new SSD hard drive and try booting up the computer without it. If the computer boots up successfully, there may be an issue with the hard drive or its installation.
  4. Check the battery: As you mentioned, the issue could be related to the battery on the motherboard. Try replacing the battery with a new one and see if that helps.
  5. Try booting into safe mode: If the computer is still not booting up, try booting into safe mode by pressing the F8 key during startup. This will allow you to troubleshoot any issues with your computer's software.
If none of these steps resolve the issue, you may need to take your computer to a professional for further diagnosis and repair.
2/26/2023 7:02:04 PM • Gateway... • Answered on Feb 26, 2023
What is the max ram I can install on my Gateway MA 3?
Pull up a RUN box. Windows key plus R. Then type in cmd and hit enter. Next, using the command prompt that has appeared, type in wmic memphysical get MaxCapacity, MemoryDevices Hit enter. Copy the number you see and devide that by 1048576 You can actually do that in the address bar of your browser. That will give you the maximum gigabytes your computer will run. https://www.maketecheasier.com/how-to-find-out-maximum-ram-capacity-of-computer/
2/25/2023 9:54:52 AM • Gateway... • Answered on Feb 25, 2023
I need a gateway laptop recovery cd
Gateway does not provide recovery CDs for their laptops. Instead, they provide a recovery partition on the hard drive that can be used to restore the laptop to its original factory settings. To access the recovery partition, you will need to press a specific key or combination of keys when the laptop is first turned on. This key or combination of keys will vary depending on the model of laptop you have. You can find instructions for accessing the recovery partition in the laptop's user manual or on Gateway's
2/21/2023 10:42:44 PM • Gateway... • Answered on Feb 21, 2023
Gateway 500xl tries to reboot after running for 3 or 4 minutes,reboot not always successful
Thats a pretty old PC but still usable. You might have a bad video card or the heat sink has failed. Adding some thermal paste to the processors heatsink will probably fix this. If not, replace or add a video card. The video card can be found pretty cheap online.
1/7/2023 3:34:00 AM • Gateway... • Answered on Jan 07, 2023
Gateway Desktop / Intel Core i3 Processor / 8GB Memory / 1TB Hard Drive (DX484011E) Logo
8 questions posted
Top Gateway Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Gateway Computers & Internet
Most Popular Question
computer crashes error code kernel
  • Computers & Internet
