20 Most Recent Panasonic DVD-S25 Questions & Answers
2answers
My dvd player do not play. it says no disc, no matter what I do
I just removed the top part and clean the laser beam with Q tip and after that it started to work back again.
4/29/2020 8:40:22 AM • Panasonic... • Answered on Apr 29, 2020
2answers
Subtitles are in french! can get to language position but can't change to English
Subtitles can only be changed if the disc menu allows for it to be changed to English
6/28/2014 9:39:19 PM • Panasonic... • Answered on Jun 28, 2014
manual
How do I connect my Panasonic DVD player DVD S25 to direct tv?
Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments. Pull up older posts. You can get all details.
6/1/2012 2:48:11 AM • Panasonic... • Answered on Jun 01, 2012
I tried to connect my Panasonic DVD player (DVD S25) to Direct TV, but it didn't work. Can someone help me do this?
There are codes to setup both devices. Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Check the related ads posted by Google along with posts. Sometimes, you might get more details from it.
5/29/2012 5:03:51 PM • Panasonic... • Answered on May 29, 2012
My player is not staying
It has a problem reading the disc, this could be caused by a worn or fault spinner belt
5/13/2011 5:47:22 AM • Panasonic... • Answered on May 13, 2011
My 3 year-old got a
3/25/2011 5:27:13 AM • Panasonic... • Answered on Mar 25, 2011
El dvd pide un codigo, cual es
You can try this:
1. Turn the DVD player on
2. Hit Setup on the remote control
3. Press 8888
4. Press Next button ( >>' )
5. "Version" menu should show up on the Screen
6. Select "Version" menu, select "Region Code" and choose 0 by pressing the down arrow on your remote.
7. Click Setup to exit
or you can buy it from here:
http://www.multiregionupgrades.com/upgrades/panasonic/dvds25.htm
Good luck,
Alex
PS-Don't forget to vote me, thanks!
2/14/2011 11:59:25 AM • Panasonic... • Answered on Feb 14, 2011
0answers
0answers
Dvd player tray keeps opening and closing.
The tray position switch is disconnected or bent from disassembly. I expect one plug wire is off when you put the unit back. The tray switch is mounted so the tray strikes the switch when fully in and fully out.
4/3/2010 4:57:57 AM • Panasonic... • Answered on Apr 03, 2010
I can't get my DVD player to play in color.
HI
As your new tv got a/v inputs if so are the set to the right sty for the country that you live in , uk and eur pal, france secam, and for usa ntsc this can be set from the menu on tv remote
3/19/2010 11:19:57 PM • Panasonic... • Answered on Mar 19, 2010
Disc spins, then " Type of disc can not be played" message
it means the format of the type of cd u put in cannot be played by the system.
try playing the disc it on another player, if it does the same, it means the disc cannot be played. some players dont play mp3 format, blu ray, and some others, so you can check the kind of disc you want to play on it.
goodluck
2/3/2010 6:23:12 PM • Panasonic... • Answered on Feb 03, 2010
Wont play dvd about 2 months old
it could be DIRTY LASER or a spindle motor or defective laser pu
since its 2 months old it probably has 90 days labor and 1 yr parts id look for my reciept and call and find out where to take it to have it looked at
11/9/2009 1:13:21 PM • Panasonic... • Answered on Nov 09, 2009
0answers
Panasonic dd-s25 won't play dvd.
HI...
Have you tried reg.CDs to see if those have trouble too?
I would say that the lens assembly has got debris or a filmy substance over the lens.
If you're not the least bit technical , dont open the unit.
It will require that the cover gets removed and the top DVD spinner plate gets removed so that the Lens can be cleaned.
The chrome rails that the DVD reader runs on would need cleaing too.
3/4/2009 4:12:13 PM • Panasonic... • Answered on Mar 04, 2009
Panasonic hds700tds playing audio no videos
  1. Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
  2. Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
  3. Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
  4. Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
  5. Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
  6. Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
  7. Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
  8. Hope this helps
4/9/2024 11:43:10 PM • Panasonic... • Answered on Apr 09, 2024
I have a Panasonic 50-in flat screen TV a storm came by and knocked out my TV and my Yukon no breaker was off so did it come through the antenna please help
  1. Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
  2. Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
  3. Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
  4. Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
  5. Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Hope this helps
4/9/2024 7:56:16 PM • Panasonic... • Answered on Apr 09, 2024
Panasonic DVD-S25 Logo
23 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
3 year old got
  • Televison & Video
