20 Most Recent
HEWLETT-PACKARD Compaq 610 Notebook Questions & Answers
HP Compaq 610 Not Charging
If the laptop
battery is more than 3 - 4 years old then the battery could be worn out.
Rechargeable batteries have a finite number of charge and discharge cycles and
will lose their charge capacity over time, i.e. won't charge to 100% and
gradually the charge reduces until the battery won't charge up at all. OR The
battery shows a 100% charge but when the adapter is disconnected the battery
drops off to zero capacity in a very short time. If the battery drops to an
unacceptable charge level then the battery needs to be replaced.
Rechargeable batteries will fail if stored in a discharged
state for long periods.
Compaq 610 laptop will not power up, any fix?
Whenyou connect the power adapter into the laptop, does the power LED lightup? If not then -The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty.Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced.If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard.This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
My speaker is not working
Check your Sound and Audio Properties. Click Start/Control Panel and
look for Audio or Sound. Make sure you have the volume turned up and not
on mute.You can also click on the megaphone at the bottom right near the time to get into the Audio and Sound Properties.Try downloading and reinstalling your Audio Drivers.
Get online
and got to www.google.com In the google search box type: "HP
Support" (without the quotes and put your manufacturer name before Support).
Look for downloads and drivers. Enter your model number and operating
system when requested. Download and install the Audio drivers.
Try using the VLC Player. It comes with drivers and codec.
Try using VLC as your player. Go to www.google.com and
in the search box type "download vlc" (without the quotes).
Look for the Video Lan download from site www.videolan.org/vlc Download
and install it. It downloads and installs in 3 minutes or so. It's
a very fast player, smooth and it can play just about any type of dvd formats
and media. It's totally FREE.
HP G72-253NR Laptop - Using an External Keyboard
I think you have a broken USB keyboard or USB port. Simply plugging in the keyboard should be enough to make it work. First try the keyboard in a different USB port. Test the caps lock to see if the LED goes on and off. Also try a different keyboard and also test it in a different computer.
HP A6519FH Black Screen Issue:
I
what computers.?? 1000's of models over 30 years. made
F10 is BIOS screens, so if that works, BIOS. and any screen
then the PC is not booting.
try booting to CD? *(a free linux live cd?) as a test.
if that works
run HDD tests. next
ill stop here, if you can get this far, we go to next step
F11 HDD reload the OS, if PC is 2006 or newer from HP.
