20 Most Recent
Lorex SG19LD804-161 Questions & Answers
How to tranfare recordings onto a usb
transfer a recording onto a USB stick ,quite simple right click on the item to transfer then it will come up with a list of what you want to do like copy to cd or another hard drive or the USB providing its plugged in it will show as the name of the USB stick or drive whatever letter the computer affixes to the drive ,simple well it should be
12/10/2011 5:53:24 PM •
Lorex...
Answered
on Dec 10, 2011
Lorex LHV1000 HD DVR. I have one that does not want to boot. Power turns on, fan is working, but HDD light doesn't blink and nothing is coming on the screen. Power button doesn't seem to work.
If your Lorex LHV1000 HD DVR is not booting up, there are a few things you can try:
- Check all cables and connections: Ensure that all cables are securely connected to the DVR and that there are no loose connections or damaged cables.
- Restart the DVR: Disconnect the power cable from the DVR, wait for a few minutes, and then reconnect it. Try to power on the DVR again.
- Reset the DVR: If restarting the DVR doesn't work, try resetting it to its default settings. This can be done by pressing and holding the reset button on the back of the DVR for about 10 seconds.
- Check the hard drive: If the DVR is still not booting up, it could be due to a faulty hard drive. Try removing the hard drive and connecting it to a computer to check if it's still functioning properly.
If none of these steps resolve the issue, it may be necessary to contact Lorex technical support for further assistance.
No hdd detected
You will need to contact your Service provider and get the unit replaced. Your HDD may be broken in your DVR.
