20 Most Recent Panasonic PT-61LCX65 61" Rear Projection HDTV Questions & Answers
0answers
Faint red bar
This model does not have a bulb. It uses older CRTs.(cathode ray tubes). Your convergence probably is off now. You may be able to re-align it, but between you and me, its an old TV and not worth putting money into. If you can adjust it back, great, it now, Id live with it until you can replace it. check your menu for convergence settings.
2/2/2018 7:48:51 PM • Panasonic... • Answered on Feb 02, 2018
2answers
Panasonic PT-61LCX65 Bulb Reset
hold the volume button down on the t.v. & the split button on the remote at the same time for about 8 to 10 seconds.The t.v. tech. did this with my panasonic 61lcx65. Also I had 2 fairly large red / orange & 1 blue spots on the screen which I thought were a result of the bulb being bad , but the tech. attached a device he called an eeprom jig & it reset the chip ? Now the picture is like new again.
7/18/2017 2:31:41 AM • Panasonic... • Answered on Jul 18, 2017
2answers
Panasonic HDTV 1080i Lamp out
If the lamp is actually out - replace it - if the lamp is still working just reset the lamp hours - at 10,000 hours it automatically says that but it is just the lamp time needing a reset.
6/6/2016 4:52:21 AM • Panasonic... • Answered on Jun 06, 2016
MY TV HAD GREEN SPOTS AND THEN WENT BLANK. I REPLACED THE LAMP AND NOW WHEN I TURN IT ON THE POWER BUTTON BLINKS GREEN 3 TIMES AND THEN YELLOW 2 TIMES. THE SCREEN STAYS BLANK
The lamp will not fix the green spots. That is due to bad polarizers in the optic block. The lamp is only a white light. http://service.us.panasonic.com/OPERMANPDF/PT44LCX65.PDF According to the manual you are not getting enough airflow which would explain the optic block failure. Make sure the TV has lots of space for air around it and is not inside a cabinet that would overheat it.
9/15/2015 1:13:09 PM • Panasonic... • Answered on Sep 15, 2015
AFTER REPLACING THE LAMP, I HAD TO PUT THE COVER ON AND NOW THE SCREEN HAS TINY BLUE DOTS AND THE POWER LIGHT STAYS GREEN. THE LAMP LIGH IS NOW ON AND RED
The blue dots are due to a failing optic block. The lamp is only making them show up more obviously. The TV is probably failing as the blue dots will get larger and eventually take over the screen.
9/15/2015 1:11:07 PM • Panasonic... • Answered on Sep 15, 2015
Why wont ps3 play out of hdmi port or input connections on Panasonic PT-61LCX65?
becaue you need to enable hdmi on the setting of your TV and perhaps you also need to adjust to the same HDMI value in both PS3 and TV Menus
4/1/2015 9:33:07 AM • Panasonic... • Answered on Apr 01, 2015
My Panasonic PT-61LCX65 has a broken screen...is it worth fixing? and can it be fixed?
No, don't waste time or money on a rear projection screen TV. Obsolete and expensive to move and repair. Move on to an LCD flat screen (with LED backlighting).
7/31/2014 9:51:01 PM • Panasonic... • Answered on Jul 31, 2014
My Panasonic multimedia projection tv -PT-61LCX65 needs a new lamp....where is the bulb located within the tv? How do I remove?
Hello, the lamp is located at the rear of the set. Unplug the tv before you start. There is a door secured by a screw, remove it to expose the lamp housing. There is a screw that secures the lamp, remove it, then you can gently grasp the handle and slowly pull it towards the rear of the set. To replace the lamp, gently slide the new lamp back in and secure it with the screw you pulled out. replace the lamp door cover, and replace the screw. plug the tv back in and turn it on, you should be fixed. Here's a link to a video on how to do it....https://www.youtube.com/watch?v=xvF36pepCOI.....tks
7/10/2014 4:30:15 AM • Panasonic... • Answered on Jul 10, 2014
Reset lamp timer
Simple answer: -vol button on set and split button on remote hold at the same time I just figured mine out!!!! So many people with so many different solutions. I read the instructions for the TV, those says to read the instructions for the lamp. I read the instructions for the lamp but this model isn't on the instruction list. For other models it says to use the volume down button on the set and the PIP on the remote. No PIP button on the remote. But wait the bottom row of buttons has a multifunction button for split screen! I tried that and it worked. I had a message that said the lamp timer was set to zero. Done! Hope this helps someone out there.
2/11/2014 6:05:18 AM • Panasonic... • Answered on Feb 11, 2014
Panasonic PT-61LCX65 61" Rear Projection HDTV Logo
201 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
green spot in upper left corner when
  • Televison & Video
