If powers up from the machine and not the remote: press OK and 1 at the same time for more than 5 seconds. If that does not work, press OK and 2 the same way.
I think you are refering to the tape itself in the VHS cassette and it not being stuck inside the Video itself!
So if you are... don't use the spray... video cassettes have a brake system inside them. It sometimes breaks. If you turn the cassette upside down so you can see the white reels, inbetween them near the bottom (where the side label goes) you will see a small hole. If you put a pen inside it should release the reels so you can turn them with your finger. If they don't turn it may be broken. In which case... Get hold of a blank tape, the same length as yours. Carefully remove the screws (5) on the bottom. See how it's put together. Once you understand how the tape moves etc. Take out the reels with the tape, then dismantle your video and put the reels with the old tape into the new holder. It should work as good as new.
PS try not to touch with fingers the tape.
Section 5 (electrical adjustments) of the service manual covers the settings of DIP switch S-4. It is used to calibrate the supply and takeup photo sensors.
Unplug the VCR, take the cover off, find the motor (probably on the
right side of the mechanism) and turn its shaft with your fingers until
you have run the tape back out. Now plug it back in and try it
again with a scarificial tape. If it continues to fail, replace
all the rubber belts in the mechanism.
Hope ya fix it!
Its a trash tape is glued itself and there is nothing you can do.Maybe but maybe you can try to disasembly the cassete and manualy rotate the wheels but this is not recomanded you can damage video head by using this tape
Hope ya fix it!
When a tape won't eject, the problem can be caused by several things. The most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the tape. This can be fixed by either using a re-grip solution on the belt or have the belt replaced. Another possibility is that the tape is caught aroung the spindle guides that pull the tape around the video head. If the tape is caught in the spindles, this will affect playback performance. The heads could be dirty too. Another possibility for poor playback is a slipping idler wheel. The idler wheel is a rubber tire that pivits between the tape sending and pickup reels. It's a key part during playback, fast forward & rewind. The idler tire can also be treated with a re-grip solution or be replaced. Belts are inexpensive but sometimes difficult to get to. Most of the repair expense will be in the labor.
Check the Input Source: Make sure you have selected the correct input source on your TV for the device you are using. Use the remote control to cycle through the input options until you find the one connected to your video source.
Check Video Connections: Ensure that all video cables (such as HDMI, component, or composite cables) are securely connected between your TV and the device you are trying to watch content from. A loose or faulty cable connection could result in a loss of video signal.
Restart the TV and Video Source: Try restarting both your TV and the device you are trying to watch content from. Power off both devices, wait a few moments, and then power them back on. This can sometimes resolve temporary glitches or issues with the video signal.
Check for Software Updates: Make sure your TV's firmware is up-to-date. Sometimes software updates can resolve compatibility issues or bugs that may be affecting video playback. Check the settings menu on your TV for an option to update the firmware, or visit the manufacturer's website for instructions on how to do so.
Reset Video Settings: If you've made any changes to your TV's video settings, such as resolution or picture mode, try resetting them to their default values. This can sometimes resolve issues with video playback.
Try a Different Device: If possible, try connecting a different device (such as a DVD player or gaming console) to your TV to see if the issue persists. This can help determine whether the problem lies with the TV itself or with the original device you were using.
Contact Panasonic Support: If none of the above steps resolve the issue, it's possible there may be a hardware problem with your TV. In this case, you may need to contact Panasonic customer support for further assistance or to schedule a repair.
Check the Power Cord: Ensure that the power cord is securely plugged into both the TV and the power outlet. Make sure there are no visible signs of damage to the power cord or the plug.
Inspect the Power Outlet: Try plugging another electronic device (such as a lamp or a phone charger) into the same outlet to verify if it is functioning properly. If other devices work fine, then the issue is likely not with the power outlet.
Check for Tripped Circuit Breakers: Check your circuit breaker or fuse box to see if a circuit breaker has been tripped or a fuse blown. If so, reset the circuit breaker or replace the fuse and try plugging in your TV again.
Test with Different Power Source: If possible, try plugging your TV into a different power source altogether, such as a different room or building. This will help determine if the issue is specific to the power source you were previously using.
Contact Panasonic Support: If none of the above steps resolve the issue and your TV still does not power on, it's likely that there is a hardware problem with the TV itself. In this case, you may need to contact Panasonic customer support for further assistance or to arrange for repairs. Be sure to provide them with details of the troubleshooting steps you've already taken.
Turn off and unplug the projector.
Locate the lamp cover on the projector.
Remove the lamp cover.
Take out the old lamp.
Insert the new lamp.
Replace the lamp cover.
Reset the lamp hours:
Press the Enter button to display the "Option" menu.
Use the 5 or 6 button to select "Lamp Runtime".
Press and hold the Enter button for approximately 3 seconds.
The "Lamp Runtime" will change to "Time Reset [Power Off]".
Turn off the power and disconnect the power cord.
Finally, plug in and turn on the projector.
Remember to consult your projector's operating instructions manual for specific details and safety precautions. How to change Panasonic vx 400 xga projector lamp change or replace (youtube.com)
JustAnswerhttps://www.justanswer.com > Electronics Question
Jan 5, 2018 - The F60 error is an error that indicates a video processing board failure. Here are a few things that you can try (do one first then try number ...
1 answer · Top answer: Hi, I'm JA Engineer. Welcome to JustAnswer. I'm reviewing your question now and will post back ...
Reddit · r/VHS2 comments · 2 years ago
The VCR and DVD recorder won't eject/open on command either, so my guess is the capacitors on the power board are dead. Upvote
Question edited for clarity. I doubt your television id 58 FEET (58')
You don't give the model number or what you are trying to sign into? WiFi, Netflix, Cable, Parental Controls?
Here are some manuals
Panasonichttps://na.panasonic.com > ...
PDF
You need to subscribe to a cable TV service to enjoy viewing their programming. ... Check the input signal compatible with this TV. (see page 52 - 53). Page 55 ...
58 pages
Panasonichttps://help.panasonic.ca > viewing
PDF
• Has the battery run down? • Has the TV POWER button been turned On? • To operate external equipment of other manufacturers, register the remote control ...
35 pages
