20 Most Recent Panasonic AG-DV1000 Mini DV VCR Questions & Answers
Panasonic ag-dv1000 f04 error
F05 is better.
1/22/2015 10:57:16 PM • Panasonic... • Answered on Jan 22, 2015
Cpsman motor
That sounds good...go for it.
1/22/2015 10:21:35 PM • Panasonic... • Answered on Jan 22, 2015
Panasonic Ag-DV1000 mini DV deck shuts down after inserting tape
When there's a problem with the drive mechanism of a VCR it will shut down to prevent damage. All operations of a VCR are controlled by a computer chip. This is told what mode the mechanism is in by a Mode Switch. If this is faulty it can cause the machine to play up. Sometimes a spray of Video 40 on the mode switch can restore operation. However it will not correct the problem if the mechanism has any damage on it.
5/15/2014 9:51:58 PM • Panasonic... • Answered on May 15, 2014
I have a AG DV1000 mini DV deck I can't turn
Hello, thanks for using Fixya.com
I would check another power source, if it still does not turn on you might have a bad fuse inside the unit witch would need to be replaced and inspected for cause of blow out.
Panasonic would take it under out of warranty bases you might want to give them a call and ask about a local factory repair shop. Most VCR and TV repairmen in your local area if you cannot find a factory service center would be your best bet.
I would not open the unit unless your knowledge fits your budget because of hazards and other occurrences can occur.
Give this website a shot for parts and service locations
Please let us know if you have any further questions,
Best regards,
Rulds2008 Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
6/14/2011 11:43:10 PM • Panasonic... • Answered on Jun 14, 2011
Speak portuguese?
If you haven't got the user manual you can get it free from Panasonic's website. I assuming you want to switch it to another language?
2/24/2011 12:38:22 PM • Panasonic... • Answered on Feb 24, 2011
F 03 Display (Mechanical lock-up
Examine the mechanical section for signs of damage. Such as broken plastic parts. I should treat the mode switch as possibly faulty with any vcr showing these kind of compliants.
2/19/2011 10:35:55 AM • Panasonic... • Answered on Feb 19, 2011
When I insert a tape in the player,I am getting a
You have a fault with the unloading mechanism
10/27/2010 2:08:46 PM • Panasonic... • Answered on Oct 27, 2010
Need part or repair.
If I were you I would try and get a service manual for the model, this should give you the part numbers that will make it easy to track it down. Though by the sound of it the service centers sound like they want to replace the entire VCR mechanism, when it could be only one small part that needs replacing! You could hunt around on the web to see if you can get the manual free, but if you can't try Manuals in PDF.
They are very good.
Another place to try is Curry's Partmaster website. It will list all the bits for your model they stock!
True Panasonic parts supply sites are CPC and Willow Vale.
You should also list the fault on FixYa to see if the techs on here agree with the findings of the two places.
5/20/2010 11:00:59 PM • Panasonic... • Answered on May 20, 2010
My panasonic AG-DV1000P vtr
The takeup spools could be faulty,not returning the tape fully.
2/9/2010 9:30:27 PM • Panasonic... • Answered on Feb 09, 2010
Can I get a driver to connect the AG-DV1000P to my
does the AG-DV100P have a firewire output connection?
If it does your mac should be able to 'when connected' have the driver of this machine built into the OS.
2/3/2010 6:48:55 PM • Panasonic... • Answered on Feb 03, 2010
2answers
Will not seat DV
most likely problem is a defective cassette housing.
7/10/2009 7:50:32 PM • Panasonic... • Answered on Jul 10, 2009
Does not power up
Main board is  corrupt.
 Check all connectios on the main board near power supply. Change the blown capacitors/diodes.
Any further help, let me know.
Thanks for using Fixya.
4/4/2009 4:48:26 PM • Panasonic... • Answered on Apr 04, 2009
Panasonic DV-1000 Recording Problem
if you are inputting video via the s-video connector, check to make sure the cable is good. you may be losing the color signal in the cable.
12/10/2008 1:53:17 PM • Panasonic... • Answered on Dec 10, 2008
Will not power up at all!
check the main board for bad solder connections near the power connection.
10/28/2008 12:20:18 PM • Panasonic... • Answered on Oct 28, 2008
Unfortunately, all I know about Muncie is that I have relatives there. I'd go to the Panasonic website and use your zip code to locate a local authorized service center. Follow the link below and click on the "find a servicer" button in the upper right corner.
Dan
http://www.panasonic.com/support/?cm_re=1-_-Top%20Mast-_-Support
8/20/2008 6:44:16 PM • Panasonic... • Answered on Aug 20, 2008
AG-DV1000 Mini DV
The message indicates that an internal problem was detected and that the unit has shut down to prevent damage to the tape. The tape will need to be removed by hand. I can not receommend a repair location without knowing where you are.
Can you post an update with your location?
Thanks,
Dan
8/20/2008 11:45:12 AM • Panasonic... • Answered on Aug 20, 2008
AG-DV1000 Mini DV... ERROR F09
I believe that this error message indicates that the heads are not spinning. The tape should be ejected. This unit requires a servicer. There are a number of reasons for the heads not spinning. Finding out the cause in your specific unit will require testing and measurements with test gear. There are no user serviceable parts inside these units. Please see an authorized Panasonic service center.
Dan
6/3/2008 11:50:54 AM • Panasonic... • Answered on Jun 03, 2008
3answers
Cant record in Panasonic AG-DV1000 using firewire
clean the heads; often, heads that will play back a pre-recorded tape may not record because of dirt.
4/29/2008 2:12:21 PM • Panasonic... • Answered on Apr 29, 2008
Panasonic AG-DV1000 Mini DV VCR Logo
39 questions posted
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Televison & Video
Most Popular Question
need part or repair
  • Televison & Video
