20 Most Recent
Panasonic SC-HT17 System Questions & Answers
My panasonic SC-HT17 home theatre
sounds like you had a power surge. yhou need to unplug your system from the wall for about 30 minutes to reset the on board surge protector. also if your comfortable you may wanna open it up and see if you blew a fuse on the board PLEASE LET ME NOW IF HELPED YOU OUT.*KEYBOARD STUCK ON CAPS SORRY
3/17/2011 6:21:00 AM •
Panasonic...
Answered
on Mar 17, 2011
Hi
i have a Panasonic
I have PANASONIC MODEL NO. SB-WA15, the radio works but when i try to work it witht he t.v. it does not come through the speakers. what do i do? i need help before the superbowl tonight!
2/6/2011 9:41:45 PM •
Panasonic...
Answered
on Feb 06, 2011
Display screen not working.
Either the display itself (electro-luminescent) is defective, or the cables/connectors hooked to the display may have come loose. It should not be too much trouble to open up the case and have a look inside. Go for it.
2/28/2009 4:44:04 AM •
Panasonic...
Answered
on Feb 28, 2009
Salvage Job
This should not be a problem. Cut off the plug off the wire oppisite the sub connection. Turn on the sub and touch each wire till you hear a buzz, that should be your source wire. Connect up an RCA plug with the ground of course, and you should be set. Good Luck
1/25/2009 9:21:56 AM •
Panasonic...
Answered
on Jan 25, 2009
Wiring Schematic
You can get what your looking for here:
http://www.manualdirectory.co.uk/Audio___Hi_Fi_Resources/Panasonic/Panasonic_Home_Theater_Systems/index.html
http://www.retrevo.com/s/Panasonic-SC-HT17-Home-Theater-Systems-review-manual/id/356bh949/t/1-2/
6/27/2007 11:52:21 AM •
Panasonic...
Answered
on Jun 27, 2007
I have a panasonic sa vk880 and it wont give sound outputs, when i click on subwoofer button or surrounded enhancer it says error, please help
Try disconnecting all of the speakers except the left and right main speakers. If it works, check the wiring at the back of each speaker to make sure there aren't any shorts between the terminals. Better yet, just inspect the terminals both at the audio unit and the backs of the speakers. Stray strands of wire reaching across to the other terminal or exposed wire on the other side are a common problem.
If you have that all cleaned up and still have the error, you may have shorted transistors in the output amp of one of the channels, very likely the subwoofer. This may be caused by shorted speaker wiring, or the amp may have failed on its own. In either case, you would have to replace both of the output transistors for that channel (they may be built into a power amp module, in which case the module must be replaced). This requires soldering skill, and the knowledge to identify the transistors and check them with an ohmmeter. Most of the time, it's a basic job for any skilled electronic technician. (I did run into one model that would have required two days of disassembly labor just to get at the failed transistors - I told the customer that wasn't designed for service and he would be better off buying something different to replace it.)
Panasonic SA AKX71 controller
Original CD Stereo System comes with remote control and that does not need to connect. Moreover, buttons and switches are also given for manual use. If you want to use universal remote control, please specify make and model.
