20 Most Recent Homelite Gas, 20 In. Bar, 46 CC, Chain Saw, UT10520 Questions & Answers
What is air gap?
Refers to the spark plug gap.
11/10/2015 6:08:35 PM • Homelite Gas, 20... • Answered on Nov 10, 2015
Idles wide open
Sounds like the inner cable is too short, what you can do is gently snip off a peice of the outer cable where it anchors, this will make the inner longer.
3/28/2015 11:03:48 AM • Homelite Gas, 20... • Answered on Mar 28, 2015
Is there a replacement part other than plastic for clutch
you could either use an organic rubber type simelare to platsiic and do it urself - size etc
4/17/2012 7:19:47 AM • Homelite Gas, 20... • Answered on Apr 17, 2012
Will only run about 20 seconds
I think this sounds like a fuel starvation issue, depending on the model there can be numerous pipes from the tank, if it has a fuel primer bulb there will be a pipe from the tank to the back of it, there will also be a pipe to act as a breather to stop a vacume building in the tank, and finally a pipe directly to the carb, if there is a leak from this pipe you will have problems, on the tank end there will be a filter on the end of this pipe, if it is blocked it will cause this type of problem
3/4/2012 9:59:26 AM • Homelite Gas, 20... • Answered on Mar 04, 2012
2answers
I have a Homelite UT
lI thinkthe oil to gas is too rich with Gasoline. My book says 40 to 1. Not enough oil will cause it to run hot and burn or stick. Also some of the later models take the synthetic oil andif you use the outboard or other oil it will run hot and ruin the saw.
9/24/2011 6:49:24 PM • Homelite Gas, 20... • Answered on Sep 24, 2011
Chain brake not working right
strip cover and check that all the dirt etc is cleaned out and the brake band is in the correct position If the brake band looks worn ie thin in places replace with new one. Dirt can also get in the pivot of the chain brake handle and cause it to jam, saw should be stripped and cleaned at the end of every days use and the bar turned over to even out the wear
5/5/2011 11:04:45 PM • Homelite Gas, 20... • Answered on May 05, 2011
Gas/oil ratio
The ratio is 50:1.
If you appreciated my help, I'd appreciate your vote. Thanks,
Handie Andie
4/7/2011 10:46:38 PM • Homelite Gas, 20... • Answered on Apr 07, 2011
0answers
My Homelite UT10526B Chainsaw is
return it, any repairs from you will void the warrenty
3/21/2011 4:58:59 PM • Homelite Gas, 20... • Answered on Mar 21, 2011
HOW DO YOU ADJUST TENSION ON CHAIN FOR HOMELITE
Turn the tightener till the chain in the center of the bar at the bottom just hangs down about a 1/8"....
this will be good... too tight and the chain will not turn...too loose and it will come off...
that 1/8" is usually great for any saw...
heatman101
3/19/2011 5:31:13 PM • Homelite Gas, 20... • Answered on Mar 19, 2011
HOMELITE 20'' CHAINSAW BOUGHT FROM
ther is fuel mixiture problems- if it is under warranty - its dann give warranty repair.
3/6/2011 10:22:28 PM • Homelite Gas, 20... • Answered on Mar 06, 2011
Need gas/oil mix for Homelite 330 10604A, HJ
To the best of my recollection the 330 is an older model saw and should be running about a 16:1 ratio. 8oz. of oil to 1 gallon of fuel. Hope this helps.
Note: You're always better being a bit richer (lower ratio) than you are leaner (higher ratio).
2/20/2011 11:42:15 PM • Homelite Gas, 20... • Answered on Feb 20, 2011
Saw will not idle down,
First thing to do is remove the top cover, now check that when you release the throttle trigger the spindle on the carb returns ahainst the idle screw stop, if not check the linkage is not sticking and holding it open, if ok make an adjustment to the idle screw, if this screws right out and the revs still do not decrease, then you have an air leak through a crank seal or gasket.
2/11/2011 6:18:23 PM • Homelite Gas, 20... • Answered on Feb 11, 2011
My saw idles way too fast - how do I adjust?
Threr will be three adjuster screws on the carb ( will be holes in the cover so as to acess without removing any covers ) they will be marked L H and I( for idle ) or T( for tickover ). The T or I screw will adjust the idle speed, unscrew anti clockwise to reduce the speed.
2/11/2011 6:11:27 PM • Homelite Gas, 20... • Answered on Feb 11, 2011
Need fuel mixture specs
50:1 is the fuel to oil ratio using a modern synthetic saw oil available at home centers, hardware stores, and saw dealers. Be sure to mix the fuel and oil in it's own container, and to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Hope this helps!
2/3/2011 10:05:07 PM • Homelite Gas, 20... • Answered on Feb 03, 2011
I have a UT10519 and the chain keeps coming off
If the chain is showing signs of heavy wear, suggest replacing both the bar and the chain. Check the sprocket on the clutch hub for heavy wear on the teeth which will hasten wear on the chain teeth. Check chain oiling by running the saw tip near some cardboard at speed for a moment or two--it should throw off a thin line of oil. Tighten the chain until the lower run of chain just comes up to the bar, but not so tight that you can't turn the chain by hand. Hope this helps!
1/27/2011 9:23:00 PM • Homelite Gas, 20... • Answered on Jan 27, 2011
Homelite Gas, 20 In. Bar, 46 CC, Chain Saw, UT10520 Logo
Popular Tags
25 questions posted
Top Homelite Garden Experts
Jay Finke
Jay Finke
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Homelite Garden Expert? Answer questions, earn points and help others
View Most Popular
Homelite Garden
  • Homelite Garden
Most Popular Question
homelite ut
  • Garden
