20 Most Recent Nortel Networks M2008 Corded Phone Questions & Answers
Nortel Vista 350 Corded Phone with Speakerphone. I would like to have my caller's list back on my Vista 350, how?
Question edited for clarity. Question moved from Computers category. Page 17 refers. Make sure your Telco hasn't dropped Caller ID.
PowerTouch - Vista 350 Screen Phone User Guide
Rhode Island Telephone https://www.ritelephone.com > system-manual > powe... PowerTouch - Vista 350 Screen Phone User Guide. Installation and features ... Callers List ..
1/30/2024 5:02:54 PM • Nortel Lands... • Answered on Jan 30, 2024
2answers
What headsets are suitable to use with the Nortel N441 PHONES ?
The Nortel N441 appears to be little known and there is no one saying you can get a headphone for it. https://www.google.com/search?q=Nortel+N441+headset No manuals for it. https://www.google.com/search?q=Nortel+n441+Phone+User+Guide ..
12/4/2023 11:17:02 PM • Nortel Lands... • Answered on Dec 04, 2023
Nortel Vista 350 Corded Phone. Changing for new display module, I am not able to get Service Menu. With old works OK?
That sounds like motherboard / software or hardware version incompatibility issues. Replace the whole unit for $60. Keep the old one for parts.
https://www.google.com/search?q=Vista+350
6/11/2023 3:45:05 PM • Nortel Lands... • Answered on Jun 11, 2023
Display on nortel T7316E shows Services ON instead of date and time. How do I remove this?
Usually that means Night Mode is on. You can try to dial Feature #831 to turn it off. Cheers, Atcom https://atcomsystems.ca
4/18/2023 9:00:58 PM • Nortel Lands... • Answered on Apr 18, 2023
I am unable to unlock my voicemail on my Nortel 7316 phone system
You would need to log in as the voicemail admin using "Feature 983" followed by 102 (if you have 3 digit extension numbers) then the voicemail admin password. From there you can select MBOX and reset the password to 0000 for the mailbox in question.
4/18/2023 8:58:49 PM • Nortel Lands... • Answered on Apr 18, 2023
How can I program the calls to go to the new location but same extension # on Nortel Networks T7316 phone?
To program the calls to go to the new location with the same extension number on a Nortel Networks T7316 phone, you will need to update the call routing information in the phone system's programming. Here are the steps you can follow:
  1. Access the programming mode on the phone system. This typically involves entering a password or code on the phone's keypad.
  2. Locate the call routing configuration for the extension in question. This may be in a menu for "extensions" or "call routing," depending on the specific phone system.
  3. Edit the call routing information to reflect the new location of the extension. This may involve specifying a new phone number, a new group or queue, or a new set of forwarding rules.
  4. Save the changes and exit the programming mode.
Once you have completed these steps, incoming calls should be routed to the new location of the extension, even though the extension number remains the same. Note that it may take some time for the changes to propagate through the phone system, so it is possible that calls may still go to the old location for a brief period of time after the changes are made.
3/7/2023 11:19:08 AM • Nortel Lands... • Answered on Mar 07, 2023
Nortel Northern Telecom 350. The message light doesn't flash when message is left?
Remove the case and replace the bulb.
1/27/2023 7:00:00 PM • Nortel Lands... • Answered on Jan 27, 2023
Nortel T7316E - pre-recorded greeting not switched on?
so it all worked before to day for 20 years? OGM questions. the last land line phone on earth? 2001 to 2003 made? 2 decades old?> wow. all batteries good time and date set correctly not lost ADMIN login, Y/N not one manual has the word message in it. OGM zero why ask that, my guess is it other devices connected to this system or is the landline service providers OGM (ATT?) first goople hit finds this (the manual to do is lost now) https://www.justanswer.com/electronics/9ao5a-nortel-t7316e-phone-system-need-change.html if lost admin login, say so, or google how to reset it all.
7/8/2022 1:51:34 PM • Nortel Lands... • Answered on Jul 08, 2022
I have a Nortel Jazz 420 and it suddenly turned on pulse mode instead tone mode. How could I turn it on tone mode ? Pierre
Try this Tone dialing allows your telephone to communicate with devices and services that respond to tone signals, such as answering machines, fax, or automatic switchboards. Want to learn how to switch from pulse to tone dialing on the Nortel phone? Follow these simple steps. While on an active line, or after selecting the line, press # and the phone will switch from pulse to tone dialing. After you hang up the phone, your phone will return to pulse dialing. You may repeat these steps as needed.
6/23/2022 4:29:56 PM • Nortel Lands... • Answered on Jun 23, 2022
Nortel Vista 350. The red light is not on when I received a message on my phone?
Canada eh? Greetings from Toronto. I removed your phone number, because this site gets 11 million views every year, and a small percentage will phone and try to scam you. I believe the feature needs to be turned on my Bell Canada. https://www.florenceinc.com/docs/en/Vista350-e.pdf Or it is a false 'Message Waiting' issue which is covered here. https://www.google.com/search?q=nortel+vista+350+red+message+light+not+turning+on ..
6/23/2022 3:55:31 PM • Nortel Lands... • Answered on Jun 23, 2022
How do I include all phones on our network to ring when someone calls in on our Nortel T7316E? Currently only two lines out of six will ring.
If they are wired, ensure you are using the correct sockets with the bell wire connected.
1/11/2021 7:35:19 PM • Nortel Lands... • Answered on Jan 11, 2021
Have Nortel system. When call comes into line three, it won't recognize any buttons pushed to go to extension. All other lines work fine
Do an inquiry to find out what is on the button 1st. On hook [FEAT] *0 and the button should show what it IS not what it should have been
1/23/2019 8:24:48 PM • Nortel Lands... • Answered on Jan 23, 2019
We have one phone line. Can we conference with nortel 7316E?
You can conference people WITHIN the system. If you want to do it with 1 line and externally, you have to do that through your carrier like AT&T
12/29/2018 11:07:30 PM • Nortel Lands... • Answered on Dec 29, 2018
Nortel Networks M2008 Corded Phone Logo
2 questions posted
Top Nortel Lands Phones Experts
vince
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
View Most Popular
Nortel Lands Phones
  • Nortel Lands Phones
Most Popular Question
changing new display module am not able
  • Lands Phones
