20 Most Recent
Panasonic SC-AK630 CD Shelf System Questions & Answers
Panasonic SA-AK630 can i plug a ipod into it some
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
• An analog player with a built-in phono equalizer can be connected.
• For details, refer to the instruction manual of the units which are to
be connected.
• When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
R L
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
4/1/2016 12:06:33 AM •
Panasonic...
Answered
on Apr 01, 2016
No antenna, no radio reception
If the model number is SC-AK630, please confirm. The antenna should still be available from any Panasonic part distributor. Please confirm the model and I'll get you the part number and cost.
Dan
10/10/2013 3:07:32 PM •
Panasonic...
Answered
on Oct 10, 2013
No disc
nicely done! congradulations
3/19/2012 3:13:51 PM •
Panasonic...
Answered
on Mar 19, 2012
CD Player
You're probably right to suspect the motor, since its not spinning, and the lens is clean.
I recently had a "no disc" error that was fixed by general mechanic maintnance- taking apart the lens mechanism, cleaning, oiling and putting back together. If youre lucky it could also be your problem, and it should be a minimum repair fee.
Good luck
7/6/2008 8:32:48 PM •
Panasonic...
Answered
on Jul 06, 2008
Turning off the system
Demo mode is on. Read the user manual,there's suppose to have a "Demo" button on the unit. Press the button after you put the set in standby.
2/16/2008 9:07:14 PM •
Panasonic...
Answered
on Feb 16, 2008
I have a panasonic sa vk880 and it wont give sound outputs, when i click on subwoofer button or surrounded enhancer it says error, please help
Try disconnecting all of the speakers except the left and right main speakers. If it works, check the wiring at the back of each speaker to make sure there aren't any shorts between the terminals. Better yet, just inspect the terminals both at the audio unit and the backs of the speakers. Stray strands of wire reaching across to the other terminal or exposed wire on the other side are a common problem.
If you have that all cleaned up and still have the error, you may have shorted transistors in the output amp of one of the channels, very likely the subwoofer. This may be caused by shorted speaker wiring, or the amp may have failed on its own. In either case, you would have to replace both of the output transistors for that channel (they may be built into a power amp module, in which case the module must be replaced). This requires soldering skill, and the knowledge to identify the transistors and check them with an ohmmeter. Most of the time, it's a basic job for any skilled electronic technician. (I did run into one model that would have required two days of disassembly labor just to get at the failed transistors - I told the customer that wasn't designed for service and he would be better off buying something different to replace it.)
Panasonic SA AKX71 controller
Original CD Stereo System comes with remote control and that does not need to connect. Moreover, buttons and switches are also given for manual use. If you want to use universal remote control, please specify make and model.
