20 Most Recent
Rio PMP300 32 MB MP3 Player Questions & Answers
CD I record will not play in the Fisher DAC 243
Hey, try a diffrent cd, if the changer plays other original cds just fine, then its most likely doesn't support the format the cd is in. What program did you use to burn the disc basically everything you can tell me about the burning process you did would be helpful.
3/28/2009 8:51:02 PM •
Rio Audio...
Answered
on Mar 28, 2009
How do I change to degree mode on my porpo YH-2000
- Power Off: Turn off the device.
- Jumper Configuration: Locate the jumper labeled "S16" on the device. Initially, it should be connected to pins 2 and 3.
- Power On (Alarm+All LEDs Flashing): Turn the device back on. You'll see the alarm LED and all other LEDs flashing.
- Power Off Again: Turn off the device once more.
- Jumper Adjustment: Change the jumper configuration from pins 2 and 3 to pins 1 and 2.
- Finished: Your Porpo YH-2000 is now set to the desired angular unit mode.
If you encounter any issues, you can press the reset switch on the back of the device to reinitialize it.
