20 Most Recent Rio EX1000 CD Shelf System Questions & Answers
I don't have any solution for your problem BUT you can resolve mine : what color are the rings of the AR51 component (next to the big dissipator)
Regards
Rio EX1000 CD... | Answered on Nov 25, 2018
I think the reason is is because the song is in the wrong format where did you get the song from was it the same place you usually get songs from and did you change the format by accident this could be the only problem that you're having
Rio Audio... | Answered on Mar 28, 2018
Your answer is in this link.
https://www.youtube.com/results?q=chapter+68+carnival+rio+pearl%27s+peril
Rio Audio... | Answered on Sep 28, 2015
I would like to change the batteries but how can I get access to them?
Rio Audio... | Answered on Mar 10, 2014
ty holding in the play button see if it turns off hope that works
Rio Audio... | Answered on Nov 29, 2013
google digitalnetworksna and find their site click in help and support and see if their is a manual available for download
Ensure it is charged or it may be faulty and need service.
Rio Audio... | Answered on Dec 29, 2009
so what? be specific in posting ur problems dear
Rio Audio... | Answered on Jul 11, 2009
Hey, try a diffrent cd, if the changer plays other original cds just fine, then its most likely doesn't support the format the cd is in. What program did you use to burn the disc basically everything you can tell me about the burning process you did would be helpful.
Rio Audio... | Answered on Mar 28, 2009
The drivers can be found at the following website, although I'm not sure that your particular Rio is Mac-compatible:
http://www.digitalnetworksna.com/rioaudio/default.asp?cat=35
-Tha Mp3 Doctor
Rio Audio... | Answered on Feb 13, 2009
Hello Bernard, your Pioneer AX-311, is a two-channel, stereo amplifier, you can connect your Samsung TV, if it has audio output L and R, to an input of the Pioneer, say for the AUX input, what will get, is to listen to the sound of the TV in your Pioneer, in stereo, two channels, you can not have surround sound, because your Pioneer does not have that benefit
At the most, you can hear the sound of Samsung on the TV and the amplifier simultaneously, and you will hear a sound delay between the Pioneer and the Samsung
I hope my answer was useful
Greetings Franco Dosil
Hola Bernard, su Pioneer AX-311, es un amplificador de dos canales, estereo, usted puede conectar su TV Samsung, si tiene salida de audio L y R, a una entrada del Pioneer, supongamos por la entrada AUX, lo que va a obtener , es escuchar el sonido del televisor en su Pioneer, en estereo, dos canales, no podra tener sonido Surround, porque su Pioneer no posee esa prestacion
A lo sumo, podra escuchar el sonido del Samsung en el televisor y el amplificador simultaneamente, y se escuchara un retardo de sonido entre el Pioneer y el Samsung
Espero que le haya servido mi respuesta
Saludos Franco Dosil
Audio Players &... | Answered 11 hours ago
Hello Jane, you are asking for a 490 Jensen CD, that your door does not close, because it is not locked with that action, or does not close because it does not reach the end of the route, so that it is locked?
In both cases, check that there are no 7 strange elements, inside the CD compartment and also that the door locking mechanism is in the closed position, making it impossible to close the door, in this case, using a thin element, you can unlock the lid closure by pushing it down and then stop pushing and check if the defect was corrected
I hope your answer has been useful
Hola Jane, usted esta preguntando por un CD 490, Jensen; que su puerta no cierra, porque no queda trabada con esa acci?n, o no cierra porque no llega al final del recorrido, para que quede trabada?
En ambos casos, verifique que no hay 7 elementos extra?os, dentro del compartimiento delo CD y tambi?n que el mecanismo de traba de la puerta se encuentre en la posici?n de cerrado imposibilitando que cierre la puerta, en este caso, utilizando un elemento fino, puede destrabar el cierre de tapa empujando el mismo hacia abajo y luego dejar de empujar y verificar si se corrigi? el defecto
Espero le haya servido mi respuesta
Audio Players &... | Answered 12 hours ago
Rio EX1000 CD Shelf System Logo
1 questions posted
Top Rio Audio Players & Recorders Experts
Marvin
Marvin
Joseph Hoffmann
Andrew Taylor
Andrew Taylor
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Rio Audio Players & Recorders
Most Popular Question
need rio ex1000 power supply board
  • Audio Players & Recorders
