20 Most Recent
Pentair Intelliflo 4x160 Pool Vs-3050 Pump 011013 4 Spd (Pentair) Questions & Answers
How to replace a Pentair dynamo strainer pot
I really would need a picture to be more accurate. If you have no way to hold the lid on to get suction, you have to replace the front bowl (pot) as that is where the strainer basket is and how the flow is created. That bowl (pot) unscrews from the front housing. You have to be able to free the suction pipe from the bowl and have enough room to spin the bowl off. You may also have to remove the pressure side pipe if you do not have enough room to turn the bowl (pot) off. If you can not get the bowl off of the front plate, you will have to replace the bowl and front plate all at once.
Pool filter leak
If you can put some food coloring in it so you can see the leak better and you find a crack in internal or external on both fitting; may be find the parts are warn down some and may need some plumming tape put on them or replaced.
I have a pinhole leak in my pool filter. It is a
If it is only a pinhole it should be an easy fix. First dry the unit thoroughly, the drier the better. Then use superglue gel to patch the hole from both sides.You may wish to smooth the glue for aesthetics just make sure you leave enough so the glue can hold to the interior under pressure. The gel will dry overnight and is non-toxic. Larger holes or cracks would require a plastic welder or applying fiber glass.
Weed trimmer (2 wheeled) screeches.
All questions need full 'make model (what is is)' as first 3 words please. Very often, issues like this are a known fault and users tell the fix.
You need to track down where the screech is coming from?
Wheels
Drive Belt
Bearings
Piston rings
Or it may be battery operated?
4/24/2024 10:27:50 PM •
Garden
Answered
3 hours ago
I've a 5 litre garden pressure sprayer and it's not functioning properly. It is pumping pressure but then it's leaking it all out at top of the green handle.
Here are some steps you can follow:
Check the Seals and O-Rings:
Release the pressure: Make sure there's no pressure in the cylinder by releasing the pressure release valve.
Unscrew the pump: Remove the pump to access the internal components.
Inspect the seals and O-rings:
Look for any damaged or worn-out rubber seals.
Check the rubber seal at the bottom of the tube (where the plunger sits) and ensure it's in place.
Examine the one-way valve (usually at the bottom of the tube) and clean it. Lubricate it with silicone grease.
Lubricate the rubber washer on the plunger with silicone grease and reassemble it in the tube.
Reassemble the pump: Put the plunger back into the tube and lock it with the handle.
Test the sprayer: Pump it up and check if it maintains pressure without leaking.
Inspect the Handle and Hose:
Handle connection: Ensure the handle is securely attached to the cylinder.
Hose inspection: Check the hose for kinks, twists, or blockages. Straighten out any kinks and remove debris that might be blocking the hose.
Check the Nozzle and Wand:
Nozzle adjustment: Adjust the nozzle to the desired spray pattern.
Wand inspection: Examine the spray wand for clogs or obstructions.
Lubricate O-Rings and Seals:
Apply silicone grease to the O-rings, seals, and other moving parts to ensure smooth operation.
Test the Sprayer:
Fill the cylinder to the desired level (avoid exceeding the maximum fill mark).
Screw down the pump firmly to create an airtight seal.
Manually operate the pressure release valve to ensure it's working.
4/23/2024 5:45:51 PM •
Garden
Answered
Yesterday
What is the transportation ring on a huskvarna chain saw
The transportation ring on a Husqvarna chainsaw is a small metal ring that is sometimes fitted onto one of the bolts when the saw is new. Its purpose is to prevent the chain from rotating during transportation or storage. If your chainsaw has this ring, you should remove it before using the saw. Keep it in a safe place so you can use it again if needed. If you're looking for more information about Husqvarna chainsaws, you can refer to the operator's manual for detailed instructions.
https://www.manualslib.com/manual/3145215/Husqvarna-440.html
4/20/2024 9:45:09 PM •
Garden
Answered
on Apr 20, 2024
What are some broadleaf evergreen weeping trees?
TreeKisan is a AI- based Platform where tree farmers can know the standing tree market valuation in just 1 minute and sell to potential buyers. Easily assess the economic potential of your trees and make informed decisions. Download TreeKisan Now!
4/17/2024 9:39:10 AM •
Garden
Answered
on Apr 17, 2024
