20 Most Recent Sony NTX-2136 DHD 2Channel Car Amplifier (1000 Watts) Car Audio Amplifier Questions & Answers
Amp shuts off when the bass hits i have the big
Hello anthonydirks,
I'd suspect an impedance matching problem, specifically too low of an impedance for the amp to handle.
11/10/2009 12:11:12 AM • Sony NTX-2136... • Answered on Nov 10, 2009
Protection Light Comes on
your amp isnt getting enough power to it you may need to install a compacitor unit
3/27/2009 3:16:02 AM • Sony NTX-2136... • Answered on Mar 27, 2009
Stuck in remote mode no remote
I think you mean Xplod?
Sony RM-X151 Car Stereo Remote -Electronics
Amazon.com https://www.amazon.com > Sony-RM-X151-Stereo-Re... Buy Sony RM-X151 Car Stereo Remote -Electronics: Remote Controls - Amazon.com ? FREE DELIVERY possible on eligible purchases. Rating: 4.3 · ‎100 reviews · ‎US$8.99 · ‎In stock
xplod remote control for sale
eBay https://www.ebay.ca > sch Remote Control For Sony CFD-G50 CDF-G35 CFD-G30 Xplod CD Radio Cassette Recorder. Brand New. C $14.93. Was: C $15.87 6% off. Buy It Now. +C $4.12 shipping.
Support for Remotes for Car Entertainment
Sony https://www.sony.com > electronics > remote-controls-... Questions & Answers · The remote control doesn't work · How to obtain replacement parts, accessories or software for a Sony product. · The remote control is not ...
Sony Car Audio/Video Remotes for sale
eBay https://www.ebay.ca > ... > Audio/Video Remotes Get the best deals on Sony Car Audio/Video Remotes when you shop the largest online selection at eBay.com. Free shipping on many items ' Browse your ...
Sony XPLOD Car Remote Controls for sale
thumpingcarstereo.com https://www.thumpingcarstereo.com > sony > sony-xpl... Sony XPLOD replacement Remote Controls for sale. If you've lost or damaged your Sony XPLOD remote control, don't worry, you can replace it!
Wgthhk Replacement Remote Control for Sony RMT ...
Walmart https://www.walmart.ca > ... > Home Audio Remotes Wgthhk Replacement Remote Control for Sony RMT-CG50A CFD-G30 CFD-G50 CDF-G35 Xplod CD Radio Cassette-Corder. Price when purchased online.
12/29/2023 2:41:06 AM • Sony Car Audio &... • Answered on Dec 29, 2023
Sony CDX-M850mp isnt playing any audio from aux or cd input
This issue might be due to a malfunctioning auxiliary input or a problem with the amplifier circuit. You can try the following steps to troubleshoot the issue:
  1. Check the connection between the auxiliary input and the head unit to make sure it's properly plugged in.
  2. Check the audio cable for any signs of damage or wear.
  3. Make sure the auxiliary input is selected as the source on the head unit.
  4. Check the amplifier circuit to see if it's functioning properly. If it's not, the amplifier may need to be repaired or replaced.
If these steps don't resolve the issue, it's recommended to have the unit inspected by a professional audio technician.
1/29/2023 12:50:57 PM • Sony Car Audio &... • Answered on Jan 29, 2023
Suddenly no sound from Sony LBT-A790 amp. It is working and green light is on.
First thing we should check is the resistance in each of the speaker circuits. With the system OFF and everything connected, use a multi-meter and take a reading across each set of speaker terminals. Most home audio drivers should measure close to 8 Ohms. Report back what you find
1/13/2023 10:10:56 PM • Sony Car Audio &... • Answered on Jan 13, 2023
What is the correct way to hook up a 1000 watt Sony xplod Amp with 1 subwoofer to my Sony mp-40
To properly hook up your 1000 watt Sony Xplod Amp with one subwoofer to your Sony MP-40, you will need to connect the subwoofer to the amplifier using RCA cables. Once the subwoofer is connected, you will then need to use a power cable to connect the amplifier to your Sony MP-40. Make sure the power cable is connected properly and that the amplifier is turned on. After that, you should be able to adjust the settings on the amplifier to get the desired sound from the subwoofer.
1/4/2023 12:52:18 AM • Sony Car Audio &... • Answered on Jan 04, 2023
2answers
My Sony GT90BT car radio is not working. No power on display.
Hi, usually one uses a power cycle in order to reset the radio. If the radio is not coming on, the wires powering it could be bad so you'd want to check them with a multimeter for current. Then, you'd want to test the car battery to see if it's still powerful enough to support all of the devices in your car. Then you can get the radio checked. Thank you.
12/3/2022 5:33:54 PM • Sony Car Audio &... • Answered on Dec 03, 2022
Can 2 sony 12 inch 4 ohm subs be paralleled to 2 ohms? i have a 2 ohm stable db drive amp
Resistors (loudspeakers of equal resistance) in parallel ... divide the resistance by 2. Answer to your question is yes, you will have 2 Ohms.
10/20/2022 8:22:42 PM • Sony Car Audio &... • Answered on Oct 20, 2022
My Sony car radio keeps scanning but wont hold a station?
Did you do anything around the rear window glass? That is where the aerial is unless you have some other type of antennae. There is also a connector plug under the dash behind the radio. Your signal isn't strong enough for some reason. Have you tried switching between FM and AM channels.
8/25/2022 5:35:25 PM • Sony Car Audio &... • Answered on Aug 25, 2022
2answers
AMP shuts off
your problem could be in the fact that you are trying to overdrive the amp. sony will not carry a 1 ohm stable load and if your speaker are 4 ohm speakers wired in series then you cant drive the bass your looking for. try using soundstream tarantula amp or new hifonics block mono class d amp with about 1000 watts rms. what kicker subs do you have? that will also make the difference in amp choice. im running tarantula on 4 polk momo 4 ohm 12's and has broke my back glass in my jeep twice one time was for a show. oh well let me know. happy boom boom. i'll be glad to help
5/2/2022 2:23:17 AM • Sony Car Audio &... • Answered on May 02, 2022
Hello I have a Sony CD headunit (cdx-565up) and the face comes on but you can't do anything but turn it up and down can't switch stations can't adjust nothing just comes on turns up and down that's it
Take a cotton swab with rubbing alcohol and clean each button thoroughly to remove any residue. There is a eject lever on the device that could be out of place. To fix this some minor repair will be needed. Taking the face plate off using the small button on the lower left hand side will give you access to the reset button. Try this before opening up your entire device. Try any above of these Hope it helps you Good luck
3/13/2022 11:45:01 PM • Sony Car Audio &... • Answered on Mar 13, 2022
3answers
I cannot figure out what
dsfdsfsd
12/14/2021 4:09:44 AM • Sony Car Audio &... • Answered on Dec 14, 2021
I have a sony xr c4120 car stereo system. Can i connect mp3 player?
Same question?
11/26/2021 12:35:22 PM • Sony Car Audio &... • Answered on Nov 26, 2021
2answers
Sony explode car stereo wont get any stations on the tuner
aerial is disconnected on the rear or at the rear/front window elements.
10/27/2021 2:53:43 AM • Sony Car Audio &... • Answered on Oct 27, 2021
2answers
How do I connect a Sony xplod 1000 watt 2 channel amp to 1 10" dual 4 ohm voice coil 1500 watt planet audio subwoofer?
Connect one voice coil to one channel of the amp. Repeat with the other voice coil. Do not bridge the amp as your only choices would be series which would be an 8 ohm final load and cuts the amp power in half or parallel wiring which results in a 2 ohm load and very few Sony amps currently made can handle being bridged to a 2 ohm load.
10/20/2021 11:57:21 PM • Sony Car Audio &... • Answered on Oct 20, 2021
2answers
Best way to run my Sony xplod 1000 watt amp to two dual 4 ohm 10-in speakers
wire one speaker to left and one to right. Do not be confused by impedance. this will work.
10/20/2021 11:55:58 PM • Sony Car Audio &... • Answered on Oct 20, 2021
Car Audio & Video Logo
Popular Tags
2 questions posted
Top Sony Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
 Grubhead
Grubhead
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Car Audio & Video
Most Popular Question
protection light comes
  • Car Audio & Video
