20 Most Recent
Sony CDX-L410X CD Player Questions & Answers
Hello my car is equipped
Hello! Maybe I can help with your question. This model headunit does not support ipod control. It does not have rear or front inputs via 1/8mm jack that you could use the headphone output. You only have a couple of options here. First would be to purchase a wireless fm modulator that would transmit the ipod output through your cars antenna. (i.e. set the radio to 88.1, 88.3, etc) These can be purchased at Radio Shack, Wal-Mart, etc. The only other option would be to replace the headunit with a compatable unit. We sell a Kenwood for $139 that has a front USB port as well as the aux input. The USB on this unit reads droid phones and ipod. That model number is KDC-248U. Hope this helped! Good luck with your venture!
20 year car audio/video installer
Bay manager
Where can i buy a
I am assuming you are speaking of wire harness? And I am assuming that you are in the US?
Based on that assumption, you can purchase wire harness from Bestbuy, Cartoys, and various other electronic shops. Or you can try online sonic electronics, crutchfield, amazon, or even ebay.
Disconnected 16 pins harness to
I would say the harness or some of the pins are not lining up and need to be adjusted or you could have shorted something. Make sure the faceplace is all the way on too..
My sony cd player will turn on but wont play
reset the unit. (use the reset button if it has one or remove all power to it) check the power to any amps you have hooked up and check for short circuited speaker wires (the - wire touching the + wire) all these things will cause you to have no sound.. if that dont work have the unit looked at at a audio shop it might need replaced
