http://majorgeeks.com/BIOS_Patcher_d3965.html
Find and fix errors in your system BIOS BIOS Patcher can find and fix errors in your system BIOS (only AWARD BIOS for now) and also it can add or open new features, i.e. some features that your BIOS has but they are closed by manufacturer of your motherboard. It scans rom file. If it finds any known errors it fixes the errors. If it finds any closed features it opens it. hope this helps
go to this "Website" Scroll, to find: Select from the {List}, the "Audio Drivers" that will 'best' [Support] your Computer.
"Fill-in" or {Choose} any information needed to get the "Drivers" you need.
Than you'll be able to "Download the Drivers."
"Please let me know if you 'need' further assistance, or the 'solution' helped? "By posting a 'Comment" or 'Rating' the solution. Thank you; your 'response' is important to me!"
paul7of9
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect your hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electic extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error hope this helps
25 questions posted
790 Questions
782 Questions
456 Questions
445 Questions
428 Questions
