20 Most Recent
Dell 1210S Projector Questions & Answers
Projector is not on red light is blinking
check the lamp first
any questions, feel free to contact me
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD chip,color wheel,motherboard,powersupply,ballast... with high quality and competitive price.
have a nice day!
Jerry,Lampdeng Limited
DELL .how do i rotate the sreen 180 degrees
Anonymous,
You should be able to press CNTR+ALT+Down Arrow or Up Arrow on the keyboard to rotate the screens image. You may also go into the projectors main menu to adjust. At the link below is the online manual for the 1210s projector.
http://dell.to/1zEbfMW
Thank You,
Dell-Jesse L
Dell Social Media and Communities
How do I fix the projector not coming on
did u checked the supply it going to hi blast board power supply board ? if supply is okay then u have to check that 4 all mosfet and drive ic... just try to check later i will explain.... i m shure u will solve ur problem very soon keep it it touch with fixya....!!
My projector has lines on the screen. new bulb didn't help
If this projector is connected by Component Video (3 or 5 wires) instead of HDMI, the most common color related problems are caused by having one of the 3 video cables (Red, Blue or Green) with a bad connector. If everyone is a green smurf the problem is with the red cable. If everyone is a red smurf the problem is the blue cable. If the green was bad you wouldn't see anything.
Another possibility is if the green is plugged into the yellow jack instead of green jack on the projector, you could see what you are describing.
If everything checks out, take the projector to a repair facility.
If you are connected by an HDMI cable, (combined with the fact you mentioned vertical lines not horizontal) then take the projector to a repair facility.
All of this assumes that you don't just have a bad Cable Box or Blu-ray player or Home Theater Receiver. (The source)
White pixels or dots on the screen i have a dell 4210x projector
1,white spots appeared on screen,means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD200
have a nice day!
It over heats after 2 hours
clean the air vent
check the lamp ,whether it is a original one
have a nice day!
I've got white speckles on the projector. it continues to increase as the day goes by. Now the projector hardly stays on for more than 5 minutes before loosing color and shutting down with the indicat
To release the key lock, set the [Key Lock] to [Off] using remote control. Pressing the [RETURN] button on the projector for 10 seconds also sets the [Key Lock] to [Off]
competitive price.
have a nice day!
In my projector switch said yellow light blinking what to do
check the lamp,first
second, to check the lamp ballast
have a nice day!
After 10 to 15 automatically his off the screen
if the lamp operation time exceeds 2000 hours,
have a nice day!
skype:lampdeng
After 10 to 15 minuts automatically system display off
"Temp" light is red ,means that the projector is too hot
have a nice day!
skype:lampdeng
