20 Most Recent Sony SLV-D550P DVD Player/VCR Questions & Answers
0answers
0answers
Cant get my dvd player to open
As for temporary use you can use a simple method. You may see a small hole below the disc inserting cabin. Push the eject button and have a pin inserted well into the hole. the dvd player will eject in a matter of seconds. Actually, the problem can occur as a result of aging or someone or something must have applied so much force on the player such that the dvd cabin is misplaced. If you cant find the hole, struck the top of your dvd player hard, after pressing the eject button. Two or three tries must help.
4/7/2010 10:26:26 AM • Sony SLV-D550P... • Answered on Apr 07, 2010
Reads cds but won't read dvds
s it possible that moisture got underneath the lens? NO
try a music cd,
sounds like the lase maybe getting weak.
11/17/2008 5:30:02 PM • Sony SLV-D550P... • Answered on Nov 17, 2008
VCR Eats the tapes
Often the "Pinch Roller" type Tape Drive can "Dry Out" and it slips. this causes the tape to get all screwed up.. It could also be a belt that turns the capstan.. Or even a thing called the "Mode Switch" In any event Ya probably be best to take it in for repair as it's not really a "Homer" I suggest ya get a quote and an explanation, and see if it is economically worthwhile?
8/22/2007 2:32:50 PM • Sony SLV-D550P... • Answered on Aug 22, 2007
VHS Picture on new recorded tape shows horizontal bars.
clean the head of your vcr that will help also connections of the wires good luck.
3/30/2007 1:51:08 AM • Sony SLV-D550P... • Answered on Mar 30, 2007
I need the code from my Sony RM Y180 television remote to operate my Sony CD/DVD PLAYER DVP-NS57P please?
Question edited for clarity. This is unlikely to work, although I do see the remote has a VCR/DVD Source button. https://www.amazon.ca/Players-Kv-20Fv300-Kv-27Fa310-Kv-32Fs320-Kv-29Fs120/dp/B0874DLQMP And Sony says it is not programable DVP-NS57P The model is not programmable. https://www.sony.com/electronics/support/remote-control-programming/models/dvp-ns57p https://www.google.com/search?q=sony+dvd+remote+codes You can buy a Copycat remote for the DVD Player if yours is lost. https://www.google.com/search?q=DVP-NS57P+replacement+remote ..
4/22/2024 8:10:05 PM • Sony Televison &... • Answered 2 days ago
My sony tv bravia model klv 32v400A has no picture but the mauns light turns from red to green using the remote. What is the problem please?
This TV is 10 years old and probably requires a service that replaces the backlight invertor or just a power supply issue. Check to see if the light blinks. (That is the fault code and then google the result for more information).
4/21/2024 7:49:57 AM • Sony Televison &... • Answered on Apr 21, 2024
Sony HT-CT260 Home Theater Soundbar. Missing the manual for it?
Question edited for clarity, proper name, fix typo. Manual and Reviews
Manuals for HT-CT260
Sony https://www.sony.ca > electronics > support > product Find instruction manuals and brochures for HT-CT260.
Sony HT-CT260 review: Excellent sound that fits nearly ...
CNET https://www.cnet.com > reviews > sony-ht-ct260-review May 7, 2013 - The Sony HT-CT260 is our go-to budget sound bar pick, with excellent sound quality, built-in Bluetooth, an adaptable design, and no major ... Rating: 8.4/10
Sony HT-CT260 Home Theater Soundbar Review
PCMag https://www.pcmag.com > Reviews > Audio > Speakers Feb 28, 2013 - The Sony HT-CT260 soundbar adds Bluetooth to an already highly capable and modestly-priced two-piece audio system. MSRP $299.99. Pros and cons: Excellent value ? Built-in Bluetooth ? Treble response isn't the clearest ? View full list Rating: 4 · ‎ Review by Will Greenwald · ‎ US$225.00 · ‎ Out of stock ..
4/6/2024 7:46:33 PM • Sony Televison &... • Answered on Apr 06, 2024
Codes for SONY TV on CYBERTEC REMOTE RM-L1107+3??? Pls help!!!
Pano po ireset ang cybertec 8 in 1? Salamat po
3/19/2024 11:52:38 PM • Sony Televison &... • Answered on Mar 19, 2024
Sony older model with side speakers flashes red led after blinking green here a grinding sound when powering on
All questions need 'make model (what is is)' as first 3 words in every question please. Television? Stereo? Sound bar? ICE? The grinding noise makes me think you have a cooling fan issue, in which case the flashing LED would be signaling an overheat situation. You can Google sony model blink codes ..
3/18/2024 7:02:45 PM • Sony Televison &... • Answered on Mar 18, 2024
I NEED CODES FOR MY NEWSTAR NTR-B28Z FOR MY SONY TV
ChatGPT 3.5
User
I need code for newstar ntr b28z for my Sony tv
ChatGPT
Unfortunately, I can't provide specific code for your Sony TV remote without knowing the exact model number. However, you can usually find the code in the user manual of your Sony TV or by contacting Sony customer support. Alternatively, you can try using the auto-search feature on your newstar ntr b28z remote to find the correct code for your Sony TV.
User
ChatGPT
To find the code for your Sony TV using the Newstar NTR B28Z remote, you can try these general steps:
Turn on your Sony TV.
Press and hold the "TV" button on your Newstar remote until it blinks twice.
Enter the code for Sony TVs. Some common Sony TV codes are: 0000, 0011, 0080, 0111, 1234. If none of these work, you can proceed to the next step.
Press the "Power" button on the Newstar remote. If the TV turns off, the code is correct. If not, try a different code.
Once you've found the correct code, press the "TV" button again to lock it in.
If none of the provided codes work, you might need to consult the manual of your Newstar remote or contact their customer support for assistance.
3/7/2024 2:17:41 PM • Sony Televison &... • Answered on Mar 07, 2024
Circuit diagram of sony kv-sz25m80
str no
2/26/2024 4:44:54 PM • Sony Televison &... • Answered on Feb 26, 2024
I have a Sony Bravia model no klv-22bx350 powers on them shuts down blinks 2times
2 red light blinks can mean a power supply problem that can be caused by a problem on the main board. An authorised Sony repair shop can fix that for you.
2/20/2024 8:03:27 AM • Sony Televison &... • Answered on Feb 20, 2024
Samsung Remote AA59 00443A to Sony NS315?
Question edited for clarity and typos. No it can't be done. These are remote specifically made for one product and are not a Universal Remote. Makers don't play ball with other makers. The only exception is cable and satellite boxes allowing their devices to be co-controlled. https://www.google.com/search?q=sony+ns315+replacement+remote+control https://www.google.com/search?q=Samsung+remote+aa59+00443A ..
2/6/2024 8:24:03 PM • Sony Televison &... • Answered on Feb 06, 2024
Sony bravia codes for universal remote
You can find the codes you need to program your remote control on the official Sony website. Simply enter your model number in the search box to get started. Remote Control Codes & Programming (sony.com) Alternatively, you can try using one of the following codes to program your remote: 262 or 243 or 1071, 5321, 4981, 5811, or 1901
1/20/2024 9:14:57 PM • Sony Televison &... • Answered on Jan 20, 2024
Sony SLV-D550P DVD Player/VCR Logo
17 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
get dvd player open
  • Televison & Video
