20 Most Recent Ctm HS 6200 Folding Power Wheelchair Questions & Answers
for that go to ebay in medical batterys for powerchairs
Ctm HS 6200... | Answered on Jan 20, 2014
hi Brenda, it normally located at the rear near the controller, you will find like a black circular button type with a hole in the middle, covering up the hole will quieten it down,
Please note, if you make it quiet and there is accident when you 're backing ? , at least people know you're there.
Regards
Ctm Health &... | Answered on Feb 07, 2019
Hi, Check the brushes in both motors. i know it going okay in forward but you be surprise , at worse it's a controller fault,
Regards
Rob
Please leave feedback.
Ctm Health &... | Answered on Oct 21, 2018
Here is the manual. I am still looking for the schematic. the manual does have a god troubleshooting section. http://scooterland.net.au/wp-content/uploads/2015/08/User-Manual-HS-589.pdf
Ctm Health &... | Answered on Oct 30, 2017
Remove the top tiller console and check connections from membrane horn switch to horn. Test for voltage to the switch with a voltmeter. Check for voltage to the horn when the switch is pressed. These horns are inexpensive and easy to replace by splicing the wires and hot gluing the new horn inside the cover.Hope this helps
Ctm Health &... | Answered on Dec 14, 2016
Hi try this +44 800 096 1296. good luck try this phone number they might have youre controller .............+61 3 9329 3666...... Cheers
Ctm Health &... | Answered on Nov 01, 2016
hi Leslie, Sadly that is most likely a controller fault...
Please contact me if in the uk as i offer a free testing service...
Regards
Rob
Ctm Health &... | Answered on Aug 31, 2016
Raj,
There are a number of causes for this. What is happening is an interruption in the signal going to the controller. One of the first things to check is if the throttle is self centering, the spring maybe broken, or more likely the throttle is sliding on the pot it is attached to. A wire maybe broken in the tiller harness. Loose connections to the motor can do this. Scooter Doctor App
I’m happy to assist further over the phone at https://www.6ya.com/expert/bill_bcbb89783b08c489
Ctm Health &... | Answered on Jun 03, 2016
I would get the batteries checked for power. Just because your charger shows fully charged quite often the batteries are low but enough power for lights or horn which does not take much power. i suspect bad batteries.
Ctm Health &... | Answered on May 05, 2016
Ctm HS 6200 Folding Power Wheelchair Logo
1 questions posted
Top Ctm Health & Beauty Experts
Jeff Tilburn
Jeff Tilburn
medypharma2148
medypharma2148
Rob Hill
Rob Hill
Are you a Ctm Health and Beauty Expert? Answer questions, earn points and help others
View Most Popular
Ctm Health & Beauty
  • Ctm Health & Beauty
Most Popular Question
batteries price
  • Health & Beauty
