Screwloose IThttps://screwlooseit.com.au > Technical
Press and hold the 0 key for 10 seconds then simultaneously press START. You will then be asked to enter a code. Type "6789" and Enter. That will put you into
Missing: c3070 ' Show results with: c3070
Copytechnethttps://www.copytechnet.com > ... > Xerox
Dec 29, 2014 - Re: entering service mode. Press and hold the 0 key for 10 seconds then simultaneously press START. You will then be asked to enter a code. Type .
Most colour printers will not allow that as the software is designed to check print levels and when too low stop the ink head from getting damaged by drying up.
You posted to the category 'Question about In Office Equipment & Supplies'.
You give years and that it it a 4.3 litre engine. The important information in questions like this is FULL 'year make model', and in your case both the 1994 vehicle and the 2004 vehicle need full details.
Normally in 'will this fit in this', I use two Google tricks
1. the Versus trick
1994 make model vs 2004 make model
2. Search '2004 make model' and scroll down until you see the Wikipedia entry. Read the whole lot and see what the changes were in the generations
My gut feeling is that it won't work because the engine is 10 years apart and there must have been changes. When you start considering computer changes, you open up a whole can o' worms.
