20 Most Recent
Nokia 5310 Xpressmusi Questions & Answers
How can i know the code for nokia 5130 made of mexico?
HI what code are you looking for? whether it is network unlock code to unlock your Nokia 5130 mobile from network lock or else Security code ..If you are looking for unlock code then visit sites like
UNlocking4Free.com they are generating network unlock code for your mobile model at free of cost .Else if you forget the security code then try to reset your phone using default codes like 0000 or 1234 .If this codes didn;t help to reset your phone then visit the same site which i mentioned here they are also generating master reset code for your mobile model at free of cost you can use it and reset your phone then assign new security code
Mobileunlocksolutiones
Hi if you want to unlock your Nokia 5310 xpressmusic mobile from network lock .Then visit sites like
TheUnlockArena.com they are providing unlock code for all mobile models at reliable cost .You first check that whether the code is available for your country and network provider .If yes then pay for it and unlock your phone .
What is the unlock code for Nokia 5310xpressmusic IMEI:352072028252529
To get unlock code for Nokia 5310 Xpressmusic contact the current service provider or you can get the unlock code from online vendors like
Onlinegsmunlock.com for small price. There you have to give your Country and current network name along with your IMEI number to get unlock code. They will give you unlock code along with instruction on how to unlock. Follow the instruction correctly and unlock your Nokia 5310 Xpressmusic.
Nokia 5310 xpressmusic restriction code?
Hi, you can get the restriction code for a Nokia 5310 XpressMusic from
www.unlocking4u.com/nokia-5310-xpressmusic/rs6wp9/ at affordable cost.Here are the steps for unlocking a Nokia 5310 Xpress Music,1 - Switch on your Nokia 5310 XPRESSMUSIC
without any sim card.
2 - Don't bother as to what is displayed on your Nokia 5310 XPRESSMUSIC.
3 - Compose
#pw+CODE+1#.
4 - The Nokia 5310 XPRESSMUSIC would then display the message "SIM Restriction Off" and will be unlocked!
I for get security code
What kind of phone do you have? Then try the default code e.g. 1234or add 5 at the end on other models
I need my restriction code 5310
Hello no need to dial numbers....Asking for Restriction code means your phone is locked to another network.So, to fix this the best way is to visit mobile repairing shop.There are several websites available to unlock but I found no helpful.Good luck.Thanks for visiting fixya
Nokia restriction code?
You may try default phone and security code to remove restrictions.ur defalt phones codes is 12345 or 00000 u can use it Default 4 Digit user code: 1234 or 0000Default 6 Digit Security code: 123456 or 000000Type *#06# at the mobile screen to know IMEI no of your mobile.send the IMEI no to me and i will reply you with unlocking code.IF Problem not Solved SoPlease New Software install in the Phone Problem will Solved
